slam look or the rake look
i have a 1983 GMC sierra 1500 swb i dunno if i should slam the truck or give it the rake look cause this is my first truck and even tho it looks like a piece of crap right now i know it has some real potential so i need some of yalls guys opinions it would be greatly appretiated
glamoros piece o' lowlife
Re: slam look or the rake look
everyone and their mom slams their truck, be a man (or at least a redneck) and rake yers - hey, if my Lincoln can get lowered 1" in the front, lifted 1" in the rear, sports a huge hood scoop (fully functional) and rolls on offroad truck tires, and still pull it off pretty well, I don't see no reason why ya can't drop the front of yer truck with like 2-3" and slap some 245/60-15 front tires and some 295/50-15s in the rear and go show the ricers who actually owns the street, lol
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
[/QUOTE]this guy got it wrong
1982 chevy C-10, blue 2wd shortbox 17x9 cragar ss rims, 350V8-th400 2003 suzuki gsxr 1000-hit 175mph!!! yeah it's fast-no you can't ride it Last edited by odie82; 03-21-2007 at 08:56 PM. |
The One And Only !!!
Rakin went out in the 80's, It just doesn't look very cool anymore.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
The Crazy Machanic
I like both, but its ur truck and it has to be what you can live with not what everyone else can.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one
Mine came stock with the ass end pretty high in the air, but when I filled the bed up with band equipment it sat pretty level...then again I used mine as a truck, not a car.
Slam!!
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
![]() Join Date: Apr 2005
In my opinion I think it depends on the wheel/tire combination. Bigs and skinnies I'd say slight rake. Slammed if your using the same diameter wheel on all four corners.
85 LWB Chevy 350/350stocker with Hooker headers dual Magnaflow mufflers upgraded rearend with Eaton Posi unit with 3.42 gears needs interior work(now my DD) 96 Silverado Xcab mild drop(SOLD). |
i like both....just don't care for perfectly level.or back slightly lower.being kinda of an old school guy.i like rake..but no sixties jacked up rake.the older guys on here will know what i'm talking about.....remember,when they used to raise the rear as high as you could?
" Never look up a dead dogs butt."
I like a slight rake...but with the front lowered rather than the rear jacked up.
mine has a slight rake...but its lowered all around, + I prefer the bignlittle look, more of a drag race stance.
75 GMC C-15 short/step factory 454, lowered |
OL BLUU
![]() Join Date: Mar 2004
I vote for a slight rake with the tires tuck'n...
Yep, dats nice
#13 |
Slight and tucked!
1976 Factory 2wd Blazer - Restored 1975 SWB - Current Project 1978 Big 10 - Just for fun |
#14 |
leave it showroom stock.
#15 |
Classic87 What set-up do you have on your truck? 3"/4" Drop? Are your Tire sizes the same? I like the way it sits.
#16 | |
OL BLUU
Wheels are American TTII's: Front: 17x8.5 with 255x60's Rear: 17x9.5 with 275x60's Suspension: Front: 3" Belltech spindle and 1 coil removed Rear: Springs have been dearched 4", 2" shackles installed, and also I removed the overload leaf-spring (the bottom heavyduty leaf) Thanks, Anthony |
#17 |
What is the best stance for hard launches that will result in the best weight transfer ?
#18 |
It actually depends more on the springs and shocks than so much the stance...
#19 |
You do realize he's probably running a big block in that thing (so not really a ricer), besides it's anything but street-legal. I still stand behind my first idea - lower the front with 2-3" (use drop spindles if ya can afford it, otherwise just cut a coil and a half off the stock springs), install 15x8 fronts and 15x10 rears, throw some 255/50s front and 295/50s rear, regear to 3.73s or 4.11s or so, install some big swaybars, ditch the vacuum brake booster in favor of a hydro-boost system, get some disc brakes in the rear, and go scare the hell outta mustang people by passing them at 55mph on the outside of a 30mph-limit turn
#20 |
i like both. The rake on this truck looks so tight, i love it!
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
#21 |
Slam it:
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
#22 |
yeller
That has rake...but it is slammed too.
![]() I like our trucks static dropped, with a slight rake. I don't care for tail draggers or perfectly level trucks. But, that is just me, we each have our own style.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#23 |
that's exactly what i was thinking.pcm's truck sits very nice.guess i need a rule clarification between slammed and raked.i always thought slammed meant air baged and dropped on the rails type look,and raked was like mine and that blue one that slammed 87 posted.
#24 |
I agree. I consider lowered vehicles "lowered", rake or not. Bagged/bodydropped etc. i call slammed. Thats just me tho. My black & grey '87 is just lowered (4-6ish), my blue '87 is slammed as you can go without cutting into the body.
#25 |
a little rake is ok
Jeremy '86 GMC 1500 dropped 6" in the front and 6" in the rear 2003 Land Rover Discovery Low Life |
| Bookmarks |
