View Poll Results: What headers? | |||
FlowTech |
3 | 16.67% |
Summit |
4 | 22.22% |
Other (state what you would use) |
11 | 61.11% |
Voters: 18. You may not vote on this poll |
Flat Black, & Chrome!
Which headers?
I'm getting a pair for my birthday, and I need to find the best for under 250, what ones would you pick? They look the same to me, justa diff name??
http://store.summitracing.com/partde...5&autoview=sku http://store.summitracing.com/partde...4840140+302953 Also, I'm dropping my truck 5/7, there wont scrape will they? Last edited by Rc 415; 03-21-2007 at 09:42 PM. |
The One And Only !!!
Re: Which headers?
I bought these; http://store.summitracing.com/partde...5&autoview=sku after talking to a couple other people. One guy had 28,000 on his and still looked like they just came out of the box.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Re: Which headers?
those are indeed nice, but over my budget.
The Crazy Machanic
Re: Which headers?
I would say that they wouldnt scrap ill go out in the morning and measure mine. See how low they get from the frame.
I like the flow tech cause the say oval size the other could be round or oval. As for what are their differents are the flow tech has a tighter fit on the pipes closens other then that. I can see a differents.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Chevys Kick A$$
Re: Which headers?
I had the hooker headers and really liked them.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: Which headers?
I was running Hookers on my 81 stepside. fit nice, no problems.
I like hookers!!! ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Re: Which headers?
When you slap the new headers on, just make sure you tighten the collector gaskets every 100 miles or so for a while. I didn't do it the first time and ended up going through 3 sets before I kept them from leaking.
My truck is lowered about 4" in the front, and my A arms drag before the headers do. But I seldom have problems dragging. Just make sure to go slow over speed bumps...
1984 Silverado SWB Second Owner Featured in Custom Classic Trucks May 2013 http://www.customclassictrucks.com/f...let_silverado/ |
![]() Join Date: Apr 2005
Re: Which headers?
Hookers get really close to the starter, at least on my truck. Flowtech fit better, but they aren't as thick in tube diameter. Take a look at Hedman ceramic coated headers or maybe Dynomax. For your budget the Summit headers look like a good buy, but beware you get what you pay for.
85 LWB Chevy 350/350stocker with Hooker headers dual Magnaflow mufflers upgraded rearend with Eaton Posi unit with 3.42 gears needs interior work(now my DD) 96 Silverado Xcab mild drop(SOLD). |
Re: Which headers?
to everyone voting other, and saying hooker, do you know where i can get ceramic coated for less than 250??
#10 | |
Re: Which headers?
Re: Which headers?
I purchased Hedman "shorties" from summit a few months back. They are the ceramic coated ones. I paid $385 for them, I see that now summit has them for $410.
1976 Factory 2wd Blazer - Restored 1975 SWB - Current Project 1978 Big 10 - Just for fun |
Re: Which headers?
Sorry mine aren't ceramic coated. It's a toss between Hedman or Flowtech I guess. Hedman might be better overall as for as the way they fit and how close the bolt holes are to the actual pipe.
#13 |
Re: Which headers?
Headers can be had for under 500 dollars?!?!
![]() I'm used to seeing them listed for $1500 a set for 'vettes!! I think I may get fresh headers and pipes sooner than expected ![]()
Kurt Instagram: @kurtkphoto 1978 C10 Silverado 1991 Camaro B4C |
#14 |
Re: Which headers?
I'm running Hedman. I like them and they fit nice.
JP 1977 GMC Sierra Grande (350) 2004 Jeep Wrangler (4.0) ![]() |
#15 |
Old Time Rodder
Re: Which headers?
I'm running Sanderson block huggers for years and they are great. no problems.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
#16 |
Re: Which headers?
I like Hedman, I have a pair on my truck. They fit great, work great, and have no leaks. They give me no problems
#17 |
Re: Which headers?
Hmmm, I have a set of Hedman's on my truck now, I had to elongate 5 holes and dent 3 tubes to get the damn bolts in. Once installed the driver's side is sticking outward by 3" and the right side inward by 1 1/2". They are the BIGGEST piece of crap I ever bought. They only have about 30 mins. run time on them and are going in the trash when my Hookers and cab goes back on.
#18 |
Re: Which headers?
Guys, I appreciate your opinion on all these other headers, but like I said, I cant spend more than 250.00, so most of these comments arent helping...
#19 |
The Crazy Machanic
Re: Which headers?
go with flow tech you get what you pay for even if they look the same.
#20 |
Re: Which headers?
Just hold off a little longer until you can add another hundred, Then buy a set of REAL headers.
You will be glad you did.
#21 |
dang its hot
Re: Which headers?
I have always been a fan of hookers, have used headman,cyclone,dynomax,doug's,and some I didn't know. Hookers always fit well, perform well and last. Alot depends on the intended use. Do you research and pick accordingly. Now stop the hooker jokes,I heard them as I wrote...
