03-22-2007, 01:27 AM | #1 |
Disc Brake Kits
Does anyone know a good disk brake conversion kit for my truck? Its a '69 I/2 ton im looking for a 5 lug conversion with 6 piston calipers and drilled slotted and vented rotors with everything in the kit like dust sheilds drop spindles and master cylinder and booster etc. Thanks For any help!!
Travis
travis_moffatt@hotmail.com 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
03-22-2007, 11:01 AM | #2 |
Junior Member
Re: Disc Brake Kits
Most vendors on this site have a conversion kit for your truck but not with 6 piston calipers. I'm sure you'll have to upgrade to Baer brakes or Wilwood for those kind of calipers. Do you really need 6 pistons calipers? I know Baer has the 6 piston monoblock calipers but I don't know if it is applicable to our trucks (pretty sure they're not). Then you've got to have a bigger disc and bigger wheels too.
Baer does have a 5 lug drop spindle conversion kit but I'm sure it's not cheap. My biggest advice is to buy what you need. I plan on converting mine within the year but I'm only gonna use 2 piston calipers because that is all I need. I've got a 1969 1/2 ton 2wd and I'm just gonna buy a common conversion kit, probably not even power. Most of those kits run around $700-800. So if your looking for hipo parts like Baer and stuff you better have the $$$ to buy it and then maintain it to. Good luck with the hunt! AA
They call me, "AA." 1969 Chevy LWB-SDPC 350, TH400, old farm truck http://s123.photobucket.com/albums/o299/agronomya/ 2006 Nissan Altima-For my 2000 miles a month |
