Old 03-22-2007, 04:13 AM   #1
combustion
Backfire
everytime i puch the as on my truck after i let go of the gas it backfires extremely loud (even more when i puch it). its a gen 5 454 with an eddie mani and 750 carb. could this be because im running too rich? or my timing is off?
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 03-22-2007, 04:39 AM   #2
brak
brak's Avatar
Re: Backfire
probably a combination of the two, but i would start with the timing.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 03-22-2007, 04:58 AM   #3
combustion
Re: Backfire
well i cant tune the dam carb thats the thng. its an edelbrock carb. i have to swich out jets and things. but i do not think im overcarbureting it. its not that big of a carb
Old 03-22-2007, 05:51 AM   #4
brak
brak's Avatar
Re: Backfire
not sure why you wouldn't be able to tune an edelbrock carb...
in the front at the bottom of the carb are two screws, they adjust the idle mixture. doesn't get any easier than that.
also check the operation of your secondaries. if they are sticking open, that could cause your problem, as the mixture will be too rich for the decelerating engine.
Old 03-22-2007, 06:02 AM   #5
combustion
Re: Backfire
well i tried tem in 3 sttings. rich normal and lean. it still backfires. meaning its not the idle thats messed up. its something else.
Old 03-22-2007, 07:57 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
Re: Backfire
am I reading this right? you snap the throttle, let off then snap again. on the last snap it back fires. I get the impression it is backfiring through the carb, ie. burnt/leaking intake valves. if it is coming out the exhaust I would look at the ignition system. (points, dwell, weak coil etc.)
68C15 is offline   Reply With Quote
Old 03-22-2007, 08:36 AM   #7
cooters
Re: Backfire
intake gasket leaking or header leak will cause backfire on deceleration but on accel, is it backfiring through intake or exhaust? Valve or cam problems will backfire through card on accel. First check timing.
cooters is offline   Reply With Quote
Old 03-22-2007, 12:47 PM   #8
combustion
Re: Backfire
sorry for not being clear where is was backfiring from. its doing it through the exhaust. i checked for leaks and i got no leaks, it almost sounds like its burning up gasoline that's is left unburned on the exhaust system
Old 03-22-2007, 10:02 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
Re: Backfire
next question. is the unburned gas due to fuel delivery or ignition problems? bump the timing up by 4 degrees and retest. let me know if that changes anything.
Old 03-23-2007, 12:01 AM   #10
combustion
Re: Backfire
ok it did go away quite a bit, but now its hard to start due to precombustion. im afraid im gonna mess up my flexplate or starter. im at 16 degrees now in ignition
Old 03-23-2007, 12:14 AM   #11
bandit1
Re: Backfire
Backfiring out the exhaust is usually and ignition problem, check timing dwell ect.
1969 GMC 910
1970 GMC 1500 custom
1972 yamaha 175
"Money is just like trucks you can never have enough"
bandit1 is offline   Reply With Quote
Old 03-24-2007, 02:50 AM   #12
combustion
Re: Backfire
UPDATE. it was an ignition problem. my timing gun was broken andreading ahead in advance. it was like 10 degrees in advance, so when i thought i was setting it to 12 degrees i was actualy putting it to 22 degrees in advance. i tried it with another timing gun. that would explain the hash start with what i thought believed "16 degrees" lol
