Old 03-22-2007, 06:34 AM   #1
liljon285
That Guy
liljon285's Avatar
1978 Scottsdale Stepside..New Here.
Hi guys I am new here and need some help. I am dropping my truck 5" in the back with a DJM flip kit. Now I read the instructions and can't really understand it. Does anyone have pics of their procoess of how they installed one or helpful tips?
liljon285 is offline   Reply With Quote
Old 03-22-2007, 10:59 AM   #2
bwright
Re: 1978 Scottsdale Stepside..New Here.
Support the frame of the truck on jackstands. Support the rear axle. Unbolt the leaf springs at the front and at the shackle. Bolt the leaf spring back on but this time with the leafs under the axle. Place the saddles on the leafs and bolt everything back up.
1977 Chevrolet C10 - 305/TH350, SWB, Stepside, 3/5 drop...work in progress.
bwright is offline   Reply With Quote
Old 03-22-2007, 02:27 PM   #3
liljon285
That Guy
liljon285's Avatar
Yea but it has a bunch of other parts like.......
That is pretty much the kit itself.
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
Old 03-22-2007, 02:55 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
The 2 bottom "U" saddles mount under the axle and into the bottom of the spring perches, make sure you put them in with the 2 small holes Forward as this will pull the drive shaft out enough from the tranny to prevent binding, the 2 top brackets are your shock extenders, which you would bolt on to the shock mounts on the axle, mount the 2 red bump stops on the frame directly above the axle to prevent your axle from bottoming out on the frame. Pretty easy. search the site for pics as i've seen a few with pics of the setup
John
Malo83 is offline   Reply With Quote
Old 03-22-2007, 03:14 PM   #5
liljon285
That Guy
liljon285's Avatar
What are the two bottom brackets for?
Old 03-24-2007, 06:46 PM   #6
liljon285
That Guy
liljon285's Avatar
Oh i got what everything is for but still really cant find pics, so if anyone has any plz do me the favor! THANKS!
