Old 03-22-2007, 11:28 AM   #1
hewlett2002000
hewlett2002000's Avatar
3/4 ton coil springs
can i put 3/4 ton coil springs under my 1/2 ton 66? if i can will that make it sit about the same height as a C20? thanks
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-22-2007, 07:51 PM   #2
rodnok1
rodnok1's Avatar
Re: 3/4 ton coil springs
It might sit a little higher in the front, but the ride is gonna be alot harsher, if you put them in the back it'll be boncy as heck.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 03-23-2007, 12:22 AM   #3
hewlett2002000
im not worried about the smoothness of the ride. it cant get much worse than it is now. bad rear shocks and it had a shock that was broken in half in the front so the two front have been changed. anyways it wouldent bother me.
Respect:
