Old 03-22-2007, 08:44 PM   #1
67Step
67Step's Avatar
Question about Radiator Support
Is there any difference in the radiator support for a 1967 verses a 1969? I picked up a 69 parts truck and the radiator support is in good shape and wanted to put it in my 67. Thanks in advance.
67Step is offline   Reply With Quote
Old 03-22-2007, 09:30 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Question about Radiator Support
67-68 are the same
69-up I know are different.
BTW We are talking Chevy? GMC is a different animal.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-22-2007, 09:31 PM   #3
Bob Moore
The main difference is in the headlight buckets. The 69 uses welded on brackets to support the buckets wereas the 67 does not have the added on brackets. You may (probably) be able to cut the spot welds and remove the brackets. I can't remember if all the proper 67 holes will be there then or not. If some are missing you can make new ones.
Take your 67 buckets off the core and then compare whats missing(if anything) on the 69.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-22-2007, 09:52 PM   #4
67Step
67Step's Avatar
I am talking about Chevys, not GMC.
Matt
