Old 03-23-2007, 11:55 AM   #1
justins72rat
who makes stiff front lowering springs? 72 c20
who makes a good lowering spring for a 72 3/4. I don't think it matters if it's 3/4 or 1/2, but I want to lower the front of my truck 2-3 inches with a spring change, but don't want really soft springs. The stiffer the better for weight transfer is what i am finding out. I'm still working on the rear right now. The rear is a leaf spring (two springs removed) I am doing the axle flip, and probably a cal trac system or similar. I don't know how much the rear will be lowered by just doing the flip. What would be the next step to go lower in the rear? shackle extension? I am going to end up with the 315 50 MT ET radials on 10" rims eventually, and I want it to transfer and hook as good as possible. Thanks again guys, for all your help. I'm picking up my truck tonight from getting new exhaust. I'll post some picks soon. Justin
justins72rat is offline   Reply With Quote
Old 03-23-2007, 12:42 PM   #2
bryanw1968
bryanw1968's Avatar
Re: who makes stiff front lowering springs? 72 c20
Early Classic Enterprises.
bryanw1968 is offline   Reply With Quote
Old 03-23-2007, 01:20 PM   #3
cdowns
cdowns's Avatar
all the drag racers i've known go for softer springs for better weight transfer so the nose will lift and transfer weight to the rear wheels
Old 03-23-2007, 01:42 PM   #4
71Chev
71Chev's Avatar
We have all our drop springs custom made to the truck specs they are going into. It takes them a little longer to spec them out on the 3/4 ton. But that way the springs would still be stiff like they are now.
Les@GMCPauls.com
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 03-24-2007, 09:35 AM   #5
justins72rat
Maybe i'm wrong on the stiffer springs in the front. I'm just going off of grass dragging sleds. We would get a more instant weight transfer if we had the front slammed and very stiff. What's the best way for a truck like this....I really don't know. Anyone drag their trucks???
Old 03-24-2007, 06:52 PM   #6
falvarez12001
falvarez12001's Avatar
I got mine from CPP
falvarez12001 is offline   Reply With Quote
Old 03-24-2007, 06:54 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Got Mine From Eibach The Rears That Is..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
