03-23-2007, 12:18 PM | #1 |
Insert Title Here
? about PB drop member
This thing is def on my list of things to buy, and I am buying it regardless of the answer... but my question is, why does the truck have to be conveted over to a rack... is there anyway the kit can work with the PS system?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-23-2007, 01:23 PM | #2 | |
Re: ? about PB drop member
You would have to raise the steering box + pitman/idler an equal amount & I would bet that's alot of stress on the front rails after cutting the clearance notch.
03-23-2007, 02:47 PM | #3 | |
It would only be a matter of WHEN the steering box cracked the frame due to stress, not IF!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
03-23-2007, 06:03 PM | #4 |
Awwww shucks.
employee discount...employee discount....employee discount....employee discount.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-23-2007 at 06:04 PM. |
03-23-2007, 07:17 PM | #5 |
Also a rack is a far better design, so while you are updating the suspension, you are also updating the steering to a more modern system as well.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
