Old 09-03-2002, 04:21 PM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Is there one intake manifold above them all?
I'm hopefully gonna put Vortech heads(pre-drilled for use with 86 and earlier style manifolds) and might look into a new manifold. Are they all the same, or are some better than others? This will be a daily driver, but as much power as possible is what I'm looking for. I already have an Edlebrock performer intake, but it's about 5 years old and pretty well crusted up in the coolant passages. If there's no real difference, then I might just clean this one up, but then again I think weiands are only like $90...
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 09-03-2002, 10:28 PM   #2
Mike C
Mike C's Avatar
If you are thinking about a new intake anyways, don't bother redrilling the heads and buy either the GM Vortec or Performer Vortec. While your manifold will "fit" the redrilled heads, it doesn't accurately line up with the raised ports of the Vortec heads. This is where they gain most of their flow benefits so you are shooting yourself in the foot by not running a Vortec specific intake.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-03-2002, 10:55 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Agreeing with the last post, I would like to add that is you have a mild cam, run the performer vortec...a wild one...got with the RPM. I have run both intakes on both types of engines.
A mis matched intake/cam, is worse than a stock engine...worst case cenerio...it'll feel like a sick inline. (performer RPM on stock 305 fits that last description)
Old 09-04-2002, 12:43 AM   #4
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
How bout a performer RPM on a 350. Would that work well?
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 09-04-2002, 01:32 AM   #5
Longhorn Man
If you have the cam to support it, yeah.
That's what I have on my GMC right now. But it has quite a bit of cam.
Old 09-04-2002, 01:47 AM   #6
hjalbert
cracker
hjalbert's Avatar
my truck runs like crap, its a 350, hei, and to my knowledge i dont have anythign but a stock cam, and i have no idea of how to tell what cam i have. right now i have a performer on there, what woudl you reccomend andy, thanks
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 09-04-2002, 02:16 AM   #7
Longhorn Man
Well, the performer is PERFECT for an upgrade on a stock engine. If you have tried tuning it, and it passes compression test and you've tried all teh normall stuff, then you may be needing a carb.
But make sure you have looked at EVERYTHIGN.
What are your exact symptoms that = running like crap?
Old 09-04-2002, 02:28 AM   #8
hjalbert
cracker
hjalbert's Avatar
well, i cant say it really runs like crap, i did drive it 2400 miles no problem, but when its idleing, it is real rough at times, like to die, when i hit the brakes, it likes to die. (thats scary sometimes) sometimes it seems it should have more power then it does when going up hills and stuff. im not sure but i may have a vacumm leak, i am going to find out soon though, i am getting motivated to get this beast going right.
1972 GMC JIMMY,
1999 bmw k1200 ltc
1991 bmw k75
