Old 03-23-2007, 05:47 PM   #1
Bantha
Rewiring Truck This Weekend
I am rewiring my '64 c-10 pickup. I got a complete wiring harness from Keep-It-Clean wiring. Basically everything stock is coming out and the new stuff is going in. Hopefully my headlights I just got and the brake lights all work. If this all workd the truck will be street ready!
Anything I should know? Tips? Any wiring diagrams I may need?
Thanks!
Bantha is offline   Reply With Quote
Old 03-23-2007, 06:46 PM   #2
62 short step
62 short step's Avatar
Re: Rewiring Truck This Weekend
The only thing I can say is take your time and use some good quality connectors. That was 2 things. Good luck, Jeremy.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-23-2007, 07:53 PM   #3
rodnok1
rodnok1's Avatar
Try this linky I posted last year for a color wiring diagram they moved to FAQ
http://67-72chevytrucks.com/vboard/s...d.php?t=193429
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 03-23-2007, 11:04 PM   #4
Bryan59EC
Bryan59EC's Avatar
Also----do not hurry---keep it neat
Test individual circuits as you are installing them.
many people get hung up on the turn&taillights---be patient.
use new bulb and make sure you have a solid ground
keep extra fuses handy-----you will make an error somwhere you will need to fix.
points and HEI wire slightly different.
And for a bonus----wire your headlights thru a pair of relays---lights are much brighter and not so much electrical current is going thru the headlight switch.
Headlights pull a lot of amps.
If you don't have one already----use a volt gage and bypass the amp meter.
ammeters are testy and can cause fires.
Bryan
Bryan59EC is offline   Reply With Quote
Old 03-23-2007, 11:44 PM   #5
Captainfab
60-66 Nut
I checked them before I sent them......worked fine
And as said above take your time, and if you get stumped just stop and ask for help if needed.
Old 03-24-2007, 12:02 AM   #6
19GMC63
19GMC63's Avatar
also, make sure you have good clean grounds, grounds are good.
19GMC63 is offline   Reply With Quote
Old 03-27-2007, 03:48 AM   #7
Iron-Butt
454 club
Iron-Butt's Avatar
Take your time. I just bought wiring harnesses from m&h electric. they caome with all the factory connections. So that made it real easy.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
