Old 03-23-2007, 10:43 PM   #1
Midlothian Electric
Midlothian Electric's Avatar
Truck running funny
71 GMC 350 - Finally got my mechanic to fix the brakes and pack a wheel bearing. So with the weather being nice, I decided to go cruzing while completing some errands. Since I'm used to driving a 93 GMC Vanudra, I think I may have pushed it too hard. Speedometer read 80, GPS said 70. When I got off the turnpike, IT started acting funny, cutting off at the traffic lights. Then when I got to my destination, it cuts off. I restart, idles fine, put in drive, and cuts off again, start it again, put in drive cuts off again. I mamange to get it into a parking space, go do my business come back 20 minutes later, and It's running fine. Any thoughts, ideas?
Quenton Lee
Midlothian Electric Comapny Inc.
Electrical Contractors Since 1965
Midlothian Electric is offline   Reply With Quote
Old 03-23-2007, 10:49 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Truck running funny
Does it sputter or just die? While it stay running if you give it gas while holding the brake and shifting? Is it HEI or points?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-23-2007, 10:54 PM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Have your local parts store check the control modue for ya. They do funny things some times. I know it should not have any thing to do with the tranny but it controls many aspects of the ignition at different engine speeds. So if your idle drops when you put your truck in gear it could be the moduel. If you are not running an HEI I have not a clue as I have verry little experience with points. RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-23-2007, 10:55 PM   #4
chevy50
New Member
Just a wild guess,maybe vapor locked? Check your fuel line and see if its close to a heat source.
chevy50 is offline   Reply With Quote
Old 03-23-2007, 11:08 PM   #5
84_4x4
84_4x4's Avatar
I've heard of torque converters doing this before maybe you should check fluid level and make sure your trans fluid is not low or overheating Good Luck though
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 03-24-2007, 12:09 AM   #6
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Does your tranny draw vacuum off your intake??? If so could be a vacuum leak. Just a guess.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-24-2007, 07:34 AM   #7
dwaite72lnghrn
I would check the mechanical advance in the distributor sounds like it stuck full advance and then released after it stopped for awhile.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-25-2007, 01:13 AM   #8
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Check the fuel line and it's proximity to heat sources. Mine did the exact same thing a few years back, had to reroute the fuel line and filter away from the rad hoses.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-25-2007, 08:35 AM   #9
Definately operating temp related.I suspect carburation or torque converter.Could be vacuum or fuel/air.Doesn`t sound major.
