03-23-2007, 11:14 PM | #1 |
Axles
What's the deal with 5 lug axles inta 6 lug rear ends??? Will it work?? If not , what is the difference??
68 Chevy l/b, 4 whl disc in the foothills of No Calif |
03-23-2007, 11:17 PM | #2 |
67 shorty
Re: Axles
I've heard you can do this, as long as you use the wider drum from the mid to late 70's trucks.
67 SWB with enough parts to build two |
03-24-2007, 12:01 AM | #3 |
Son of a gun
Re: Axles
The 5 lug axle housings are about 1 1/2 inches wider (@3/4 inch per side), hence longer axles, so they will not work in a 67-70ish rear housing. I am just not sure if wider drums will fix the problem or not.
I switched out the whole rear end, it is an easy enough swap. You can find a 71-72 rearend to swap, or you could use a 73-87 rearend with a little fab work. Last edited by Bus Ted Knuckle; 03-24-2007 at 12:10 AM. |
03-24-2007, 12:05 AM | #4 |
Designated A-hole!
Re: Axles
Actually some of the 70 rears are the right width to use the 71+ axles, you just have to measure and see.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-10-2007, 11:27 AM | #5 |
73-81 axles and drums to a late 70 housing
Another question on this topic...............
I have a late model 70 C10 running 6-lug axles (wide rear end). I was going to pull a set of 5-lug axles from a 73-81 2WD which should be the same width as a late 70-72. My question......If I use the drums from a 73-81 and change out the pads to the 11 5/32"x 2 3/4", will everything work out alright for wheel track, etc.? Do some 73-81 axles run the 11"x2" pad? |
04-11-2007, 04:04 AM | #6 |
Re: Axles
Yes it will work. Get 5 lug axles out of a 73-81 12bolt 1/2 ton 2wd chevy or gmc pick up. Then grab a set of 74-87 2-3/4" x 11-5/32" brake drums to make up the difference in the widths. Then just remove your old axles and drums and install the new ones.
http://67-72chevytrucks.com/vboard/s...d.php?t=235416 And here is a link with photos of it actually done, http://67-72chevytrucks.com/vboard/s...d.php?t=215095 Mrrilla, it doesnt matter if the axles come from the 2" or 2-3/4" brakes axle, the difference is in the backing plates. Yes some 74-87 came with the 2" wide brakes, which are light duty. The 2-3/4" ones are heavy duty half tons. Just keep your stock brakes and backing plates and get a 2" brake drum. Unless you want the 2-34" brakes. Hope this helps and good luck. Last edited by Aarons72s; 04-11-2007 at 04:04 AM. |
