03-23-2007, 11:22 PM | #1 |
knew windshield ppg
hey guys,
i just got a knew windshield from the glass shop. its a ppg with the visor tint. i noticed that the glass is like a sixteenth smaller in thickness compared to original. what have you guys done to get it to fit with out leaks. do in need to buy a knew rubber also. does the knew rubber have the skinnier channel in it for the thinner glass. any help will be appreciated |
03-23-2007, 11:51 PM | #2 |
The Older Generation
Re: knew windshield ppg
I'm not sure if the channel in the rubber is thinner but I would consider getting a new one anyway.... I guess you could use some sealer in the channel but it would probably be a little messy. LockDoc
03-24-2007, 05:33 PM | #3 |
ya i thought of using the windshield caulk but i really would rather not. has anyone else had to deal with the new thiner windshield.
03-25-2007, 01:02 AM | #4 |
Too many projects
I have a new PPG window also (likely the exact same as yours) and I haven't had any sealing issues with new rubber all around. I never checked the thickness of the glass, as I took and threw the original months before getting the replacement.
Should be good to go, the rubber has a tight hold on the glass, so 1/16" shouldn't matter.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
03-25-2007, 09:27 AM | #5 |
67-72 Addict!
I also have a PPG windshield with no problems.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-25-2007, 10:14 AM | #6 |
Had my PPG for years no problems.
