Old 03-24-2007, 10:58 AM   #1
jorgensensc
jorgensensc's Avatar
Show me pics of brackets please.
Long story short.All on a 350, with no bolt holes in the heads. I have a swp with a couple of pulleys that don't line up correctly.Instead of buying new swp pulleys (junkyard aren't pairing them together and it is a mess of pulleys) I bought a long water pump because I have lwp pulleys at the house. I need to get the brackets for power steering and alternator on driverside for the Lwp, but without using head bolts for the alt brackets. Do they make such an animal? I was trying to avoid going aftermarket. Does anyone have pics of the brackets so I can go Junkyarding this week? Thanks in advance!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-24-2007, 05:20 PM   #2
454_72_4X4
454_72_4X4's Avatar
Re: Show me pics of brackets please.
I don't know of any LWP brackets that have the alt on the left or that don't use the holes in the cylinder head. (Just cause I haven't seen it, doesn't mean they didn't make it though.)
I do have a bunch of SWP pullies though, if that'd help ya out.
If ya do a search on my username you should find them in the classified here.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-24-2007, 06:50 PM   #3
FLEET72
FLEET72's Avatar
I once had a '73 El Camino where the power steering pump bracket bolted onto a casting on the pump. I wanted to use camel hump heads, no holes, so I lined up all the stock brackets and drilled and tapped the head. A little silicon seal in the hole when I bolted it all up and never had any problems.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
