Old 03-24-2007, 09:19 PM   #1
Litemup
Steel Horse Cowboy
Litemup's Avatar
In need of phone help, Tacoma, WA (Control arm problem)
I need some help with a few questions we have about the lower control arm and installing the shaft that the u-bolts go on that mount to the cmember. We've installed the new shaft and the new bushing nuts on the end, the question is how to torque the end nuts, what they should be torqued to and when they have been installed, should the control arm fall freely under its own weight, or should it be stiff and require force to move up and down. I have no clue and we are struggling with this, if anyone can answer here or if anyone local or anywhere for that matter would be willing to walk us through this on the phone it would be most appreciated.
Litemup is offline   Reply With Quote
Old 03-24-2007, 09:26 PM   #2
cabinetguy
67 shorty
cabinetguy's Avatar
Re: In need of phone help, Tacoma, WA (Control arm problem)
I have a parts truck that I robbed the spindles out of that you can look at.It is up on blocks.It would have to be tomorrow,as I live in Tacoma but my shop is in Graham.
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
Old 03-24-2007, 09:31 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Can we get a ride in the ratrod in your avatar? I will check go check my service manual in the shop.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-24-2007, 09:42 PM   #4
stllookn
stllookn's Avatar
160 ft-lb for CP10 with spacer, 190 for CP20&30. No spacer 95/135 and check for free movement. Good ones, without slop, move up and down freely.
Old 03-24-2007, 09:57 PM   #5
Litemup
Steel Horse Cowboy
Litemup's Avatar
Thanks guys I'll see if this works
Old 04-12-2007, 12:24 AM   #6
sighlurr
______________
sighlurr's Avatar
I think this thread needs some updates with pictures...
sighlurr is offline   Reply With Quote
