Old 03-24-2007, 11:40 PM   #1
greenhorn male
greenhorn male's Avatar
$5.00: Carrier bearing cross member, heater boxes, wire harness, brackets
Please respond in thread. Paypal preferred. $5.00 plus shipping.
1-Crossmember from a '72 3/4T Chevy. The extra bracket on the front was for an after market cruise control. "SOLD, bobthecop"
2-One or both heater boxes. Flapper works on the metal box with a cable attached.
3-Wire harness from a 72 3/4T(only truck I parted???). Not sure exact application but plugs into firewall. Wire is still soft and end connectors appear to be all there. (Correction 3/25/07. This may be from a 68 GMC front clip that I purchase a year ago) "SOLD Bob Moore"
4-Steering column brackets from an automatic. Most inside and outside pieces. "SOLD, 68chevylwb"
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 03-24-2007, 11:42 PM   #2
greenhorn male
Re: $5.00: Carrier bearing cross member, heater boxes, wire harness, brackets
pics
03 Tahoe
Old 03-25-2007, 09:30 AM   #3
Hart_Rod
Hart_Rod's Avatar
What's the cost for the crossmember to 32571? Thanks,
Hart_Rod is offline   Reply With Quote
Old 03-25-2007, 12:07 PM   #4
greenhorn male
Rob, it weighs 25# unpackaged, @ 25# shipping is $24 Fedex
03 Tahoe
Old 03-25-2007, 02:12 PM   #5
68chevylwb
Junior Member
I WOULD LIKE THESE PARTS .
SHIPPED TO 93309 .....ROGER
68chevylwb is offline   Reply With Quote
Old 03-25-2007, 07:19 PM   #6
qksilver
I will take the wiring harness, shipping to 28387
Pm me to remind me ,
Thanks, Steve
qksilver is offline   Reply With Quote
Old 03-25-2007, 08:05 PM   #7
greenhorn male
Roger if you take the heat tube on my other post. Just add a combined shipping of $8.00. I'll package the brackets and the heat tube in a USPS priority mail box instead of fedex as I stated in my other post.
qksilver same thing add $8.00 for priority mail shipping.
Paypal: ezapa007@yahoo.com
03 Tahoe
Old 03-25-2007, 11:38 PM   #8
Hart_Rod
Hart_Rod's Avatar
Can you point out the extra bracket that you're talking about? Has the crossmember been torched off or was it taken off with a grinder?
Old 03-25-2007, 11:52 PM   #9
greenhorn male
Rob, the piece is a bolt on bracket. If you see the first pic just to the left of the drive shaft opening you'll see two bolts and nuts. On the second pic the bracket is just to the right of the opening. It is the lighter colored galvanized "L" shaped metal. I could unbolt it if you like.
I ground the rivet heads off to remove the crossmember. Don't have a torch. The rivets are still there, you could see them in the pics. You need to grind them more and pound them out.
03 Tahoe
Old 03-26-2007, 12:25 AM   #10
Bob Moore
The harness is appears to be a forward lamp harness for a 67/68 GMC because it has no side marker lamps.
If qksilver passes put me next in line. Thanks - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-26-2007, 12:40 AM   #11
greenhorn male
Bob, you may be correct. The only truck I parted was a 72 3/4T chevy but I did purchase a 68 GMC front clip a year ago and this may have come from that clip. Thanks for catching that.
qksilver, I'm sorry for the wrong description, I have corrected it above.
03 Tahoe
Old 03-26-2007, 01:35 AM   #12
68chevylwb
Junior Member
I Will Take Both Parts .( Heat Tube & Steering Column Parts )
I Will Send $23.00 Threw Paypal . Let Me Know When These Parts Are Shipped .. Thank You Roger
Old 03-26-2007, 03:19 PM   #13
greenhorn male
Roger, I'll let you know as soon as I ship it.
Bob, the harness is yours if you want it. You could paypal $13 to
ezapa007@yahoo.com
03 Tahoe
Old 03-26-2007, 04:56 PM   #14
bobthecop
bobthecop's Avatar
How much for the crossmember shipped to 73099
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-26-2007, 06:28 PM   #15
greenhorn male
FEDEX to you would be $18
03 Tahoe
Old 03-26-2007, 07:43 PM   #16
68chevylwb
Junior Member
thank you
Old 03-26-2007, 07:44 PM   #17
Bob Moore
I did not want to get qksilver upset but it just looked like no side markers. I can send a harness to qksilver with markers if he needs it. Same price due to the circumstances. Also my brother lives in Martinez and can pick-up parts for me. He has met LJBear out in Grass Valley, Kevin in Winters, and somebody in Pittsburgh(?).
Let me know and I will paypal and get a harness ready for qksilver.
Thanks - Bob
vac, 454, T400
more to follow
Old 03-26-2007, 08:43 PM   #18
greenhorn male
Bob, I already PM'ed qksiver about my mistake and he has passed on it so the harness is yours. You might want to PM him about your harness as he seems to follow his pm's more than the thread.
03 Tahoe
Old 03-26-2007, 09:54 PM   #19
Hart_Rod
Hart_Rod's Avatar
GM,
Thanks for the info I did some measuring and I'm not going to be able to use the crossmember.
R
Old 03-27-2007, 12:53 AM   #20
greenhorn male
No problem Rob.
Bobthecop, do you want the crossmember?
03 Tahoe
Old 03-27-2007, 08:57 AM   #21
bobthecop
bobthecop's Avatar
Yes, Pm me with amount and address to mail MO.
1972 C-10
Old 03-27-2007, 08:47 PM   #22
greenhorn male
PM sent, thanks
03 Tahoe
