Old 03-25-2007, 12:27 AM   #1
1LOW64
rear end help
i want to swap out my rear end in my 64 swb with a 5 lug rear end just wondering if a 1/2 ton rear end out of a 85 p/u would work and about how much one would be any help
1LOW64 is offline   Reply With Quote
Old 03-25-2007, 04:21 PM   #2
Captainfab
60-66 Nut
Re: rear end help
That newer rearend is going to be wider than your 64 rear end. So that is going to limit you to how wide of wheels you can run without a deep offset. It can be done, but of course you'll have to cut off all the mounts on the 85 rear end and weld the trailing arm mounts to it.
Old 03-25-2007, 06:51 PM   #3
psychorodder
psychorodder's Avatar
Re: rear end help
I just changed my 65 rearend I used a 71 rearend direct bolt in
psychorodder is offline   Reply With Quote
Old 03-25-2007, 06:53 PM   #4
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Re: rear end help
yeah 71 or 72 will fit
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 03-25-2007, 06:59 PM   #5
psychorodder
Re: rear end help
I forgot to say the 71 72 rearend is 3/4 inch wider on each side this helped me for I run 20 inch tires.
Old 03-25-2007, 06:59 PM   #6
1LOW64
Re: rear end help
im on my way to baggin it so cuttin mounts is o.k. how much widder is it
Old 03-25-2007, 10:38 PM   #7
stepside66
stepside66's Avatar
Re: rear end help
so the axles are longer right but the 3rd member is still the same correct
stepside66 is offline   Reply With Quote
Old 03-26-2007, 12:01 AM   #8
Captainfab
60-66 Nut
Re: rear end help
It's gonna be at least as wide as the 71-72 rear, so 1 1/2" or more, I don't remember exactly and I don't currently have one to measure for ya.
Old 03-26-2007, 12:04 AM   #9
Captainfab
60-66 Nut
Re: rear end help
No, the 84 rear end is a 8.5 10 bolt instead of a 12 bolt. The last year for a 12 bolt in a truck was 79 I believe.
Old 03-26-2007, 11:18 PM   #10
stepside66
stepside66's Avatar
Re: rear end help
thats what I meant a 62 12 bolt and a 71 are the same so I could get one and put my 4.11 in it since I have a 700r4 in the truck
Old 03-26-2007, 11:43 PM   #11
Captainfab
60-66 Nut
Re: rear end help
To the best of my knowledge 63 was the first year for the 12 bolt. As long as the gears you have are for a pickup 12 bolt, yes they will fit in a 71 pickup 12 bolt.
Old 03-27-2007, 08:38 PM   #12
stepside66
stepside66's Avatar
Re: rear end help
right on cause I scored a front suspension off an 85 for 20 bucks and some 3 inch drop springs for 50 so the rear will need done before too long
