What factory alternator brackets do I need to move a factory driver side alternator to the passenger side? It is a 1970 big block with factory P/S and Alt on the drivers and A/C on the passenger. A/C is going away.
Thanks |
Re: Moving ALT from driver to passenger side
I used one off a Camaro. It's closer to the motor and doesn't look as out of place as the stock one does on the driver side.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
As long as you use a long pump.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
#5 | |
I want to move the Alt to the driver's side above the power steering. I will be adding the aftermarket A/C compressor to the passenger side where the alternator is now (to avoid running those long compressor lines across the engine). Here's a picture of my setup.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
Thanks mnunn454! I'll pm you.
#7 | |
I might be looking at the same situation as you, (aftermarket AC pump on the right side), in the future. I've never seen a left side mount alt bracket for a long water pump though.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#8 | |
