Old 03-25-2007, 04:44 PM   #1
sweet572
lt1/4l60e swap ????
i have a 1972 c-10 step side with a sbc and a Th350 with ford 9 in i was wondering how hard it would be to put in a Lt1 with a 4l60e it has all the accessories and pcm computer with harness what all has to be done like motor mounts tranny mounts computer wiring stuff like that how to get the gauges to work anything that needs to be done any help would be appreciated thanks
sweet572 is offline   Reply With Quote
Old 03-25-2007, 08:22 PM   #2
Wootdog
Wootdog's Avatar
Re: lt1/4l60e swap ????
There should be a link somewhere here. I didn't document my build up. I wish I had. I do have the Lt1/4L60e setup in my 67. Others here on the board also. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 03-25-2007, 09:37 PM   #3
shifty
Questionable
shifty's Avatar
This one has been beat to death . Search the forum for '4l60e' you'll get a gaggle of threads on GenII and GenIII swaps. Longest one is here:
http://67-72chevytrucks.com/vboard/s...ating+to+death
Have fun.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-25-2007, 10:05 PM   #4
BowTieOgre
Originally Posted by sweet572 View Post
i have a 1972 c-10 step side with a sbc and a Th350 with ford 9 in i was wondering how hard it would be to put in a Lt1 with a 4l60e it has all the accessories and ecm computer with harness what all has to be done like motor mounts tranny mounts computer wiring stuff like that how to get the gauges to work anything that needs to be done any help would be appreciated thanks
The link Shifty put up is a good read and one ive referred to many times during my ongoing swap. So far this is what ive had to do to get my LT1/4L60E into the '70...
Reprogram PCM for no emissions, different axle ratio, tire height, delete VATS.
Rework harness to get rid of all the wires I dont need.
Use 6 cyl towers and new sbc mounts
Notch frame for A/C
EFI tank with pump and new 3/8" supply and return lines
The Optispark is a PITA to get to so while you have the engine out of the vehicle go ahead and at least put a cap and rotor kit on it.
Take a read in that link, good stuff.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-25-2007, 11:04 PM   #5
sweet572
thanks that thread was a ton of help
