Old 03-25-2007, 08:03 PM   #1
bowtieride
Need help quick, Paint gun problem
so i went to start painting my truck a few hours ago, and i was spaying an old hood to get my pattern and spray adjusted right. I had it just about right when the paint started leaking out of the tip, and now it wont stop inless i tighten down the adjustment skrew all the way. I cleaned it all up and its still doing it. I can get the pattern right, but when i stop spraying it just leaks paint everywhere. Ive checked the air pressure and its not that. I dont know what to do now, and i have a gallon of primer already mixed with the reducer.
Thanks for any help guys!
bowtieride is offline   Reply With Quote
Old 03-25-2007, 08:09 PM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: Need help quick, Paint gun problem
Paint is too thick. It isnt reduced correctly.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 03-25-2007, 08:14 PM   #3
bowtieride
I thought of that, but wouldnt it leak out more if the paint was thinner? Thats the only reason i didnt try it. I mixed it in a measuring bucket too. 4-1 mix.
Old 03-25-2007, 08:23 PM   #4
cooters
you have some crap in the gun, pull the adjuster out and the tip and clean it good.
cooters is offline   Reply With Quote
Old 03-25-2007, 08:37 PM   #5
BarryB
BarryB's Avatar
Sounds lke there is some trash around the needle seat. Take the gun apart and clean it really good especially in the trigger part. The needle valve.
Is it a siphon fed gun or gravity feed??? either way there is something not letting a valve shut off completely
BarryB is offline   Reply With Quote
Old 03-25-2007, 08:45 PM   #6
sleepyboy
'69 Step
1. Trash in needle seat (I agree) 2. Are all the air holes open in the inside and outside tip?. 3. Little hole in top of cup open? Welding wire works great to clear all the holes.. IF the paint bubbles in the cup, or leaks, take it apart, clean it again and spray about 1/3rd of a cup of thinner through it. Usually works for me... ONE more. Did you strain your paint????
sleepyboy is offline   Reply With Quote
Old 03-25-2007, 08:50 PM   #7
rage'nrat638
rage'nrat638's Avatar
what pressure are you putting thru it?
should only be about 30-40 psi depending on the paint, gun, distance from surface
heres some pointers
http://www.pfonline.com/articles/0103qf1.html
http://www.autobodypro.com/tektips/a...spray_guns.htm
rage'nrat638 is offline   Reply With Quote
Old 03-25-2007, 09:00 PM   #8
bowtieride
Thanks alot to all of you. I will let you know if i get it fixed tonight. Thanks again
Old 03-25-2007, 10:00 PM   #9
49studebaker
49studebaker's Avatar
Thanks Rage, I just printed the above information as I'm new to painting and this should help. It's guys like you that make this forum so awesome. Lots of info!
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 03-25-2007, 11:14 PM   #10
rage'nrat638
Thumbs up Re: Need help quick, Paint gun problem
no problem brother. heres my truck that was shot in my garage
Old 03-25-2007, 11:19 PM   #11
bowtieride
I got it fixed guys, thanks again. Does anyone know how long primer will last once its been mixed with reducer if its kept in a can air tight?
Old 03-26-2007, 01:04 AM   #12
cabinetguy
67 shorty
cabinetguy's Avatar
This is why I try to tell you guys to get a Binks 2001.On the cheaper guns they use this packing around the needles that make your gun stick on.I spray with my gun about once a weak ( laq.) and just keep the 2 qrt. with some thinner in it. THATS IT.Rinse the tip and spray
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
Old 03-26-2007, 01:07 AM   #13
cabinetguy
67 shorty
cabinetguy's Avatar
The can will say 2-3 hr. pot life. More like 20-30 hrs if you put some thinner in it. DP90?
