Small block in a '53
Will a small block fit in a '53 with the stock steering column and steering box using either stock exhaust manifolds or block hugger headers?
Re: Small block in a '53
Small block will fit, but you will need to shim the steering box out
away from the motor a little. I dont remember exactly how far, maybe .75 inch. |
I got a '54 with a 350 sbc and cast iron headers with MII front and an 70's steering column:
![]() Not sure if this helps though.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#4 | |
Should with very little problems .... ![]()
http://i142.photobucket.com/albums/r...MyExtremeD.jpg ~ '55 Chevy Pro-Street P.U. Powered by 396c.i. ~ ~ '01 ChevyS10 Extreme LS Ext. cab ~ '92 Camaro RS 25TH.Limited Edition Aniv.Convert. ~ '98 Dodge Ram Van 5.7 Litre ~ '98 E-Z-GO Golf Car ..Tony Stewart Edition !! '69 Camaro SS..SOLD .. Still crying !! ![]() |
with gas at $3.00 a gallon i'm gonna put a later 6 in mine. they fit real good with no clearance issues.
