Old 09-03-2002, 09:45 PM   #1
KD
Truck Nut
how to tell what year front axle?
I know that I dont have the front axle that came with the truck as I have a '67 4x4 ,the axle in there now has disc brakes and when I put the front lift in the u bolts didnt fit,they were 3 inch and the axle needed 3 1/4 . I was cleaning up the cv joint and noticed spicer written on it.Just curious as how to tell for sure.KD
'70 3/4 manual w/350 4.56's .Doing a ground up on a '67 4x4 4"lift.
KD is offline   Reply With Quote
Old 09-03-2002, 11:52 PM   #2
palallin
Are the knuckles closed (enclosed in a globe) or open (with the u-joint visible inside)?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-04-2002, 12:52 AM   #3
JJk10
chevk10
I might be wrong in thinking this but if I remeber some of the U-bolts on the front axle are diffent sizes depending on where on the axle they are.. my dana 44 has a disc brake conversion and is a 1970, it has smaller u-joints then the later one if I was to use the later shafts...I am sure there's a difference in the diameter of the axle tube itself, with the earlier design being smaller. I think I had to reuse the u-bolts I had made for the front the previous spring to get my lift to work. hope this helps, or atleast helps somone else point you in the right direction
Displaced Canadian in Monterey California
1970 K10, 350 HEI, 4spd. 3.73's NP205 33"BFG Mud Terrains Edelbrock Intake and carb. 12 bolt rear,dana 44 front with disk brakes
JJk10 is offline   Reply With Quote
Old 09-04-2002, 07:19 AM   #4
KD
Truck Nut
What year front axle
the knuckles are open as you describe them.
