03-26-2007, 12:36 AM | #1 |
Truck Enthusiast
not a good day for me
well, i got my disc brake conversion in stalled along with my new 2.5" spindles and 2" springs. i go to put the wheels back on and.....they don't fit!! My dumb a$$ thought my bolt pattern was 5 on 5, stock drums are 5 on 4 1/2, new rotors are 5 on 4 3/4, my new $$2500.00 rims that should be here anytime are 5 on 5
any suggestions? can i get a 5 on 5 rotor to fit magaughy spindles? i should be able to get a set of moser axles for the rear also with 5 on 5 right?
'85 swb |
03-26-2007, 12:46 AM | #2 |
67 shorty
Re: not a good day for me
5 on 4.5 is ford car.....5 on 4.75 is GM car.....5 on 5 is GM 1/2 ton truck from 71 and up till the metrics
67 SWB with enough parts to build two |
03-26-2007, 12:48 AM | #3 |
67 shorty
Oh and large GM car is 5 on 5 also
03-26-2007, 12:48 AM | #4 |
Truck Enthusiast
my '68 stock drums all the way around are 5 on 4 1/2...hhmmm
'85 swb Last edited by droppedgmc; 03-26-2007 at 12:49 AM. |
03-26-2007, 12:50 AM | #5 |
67 shorty
stock drums are 6 on 5
03-26-2007, 12:50 AM | #6 |
Needs a Big Block
your STOCK drums should be 6 on 5.5
gm truck spindes are 5on 5 put stock rotors on it and you should be fine.
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
03-26-2007, 12:52 AM | #7 |
Junior Member
I don't know if this will help but I ordered a complete front end kit that had spindles, rotors, ball joints the whole nine yards but was for six lug wheels. At the last minute I decided to go with five lug wheels so my lug patern was wrong, I went to autozone and bought two replacment rotors problem solved, everything bolted up fine.
03-26-2007, 01:24 AM | #8 |
Truck Enthusiast
thanks, i think im going to try and get different rotors and new axles.
My truck is 5 lug, not 6.
'85 swb |
03-26-2007, 01:27 AM | #9 |
67 shorty
First why would you have 5 on 4.5 ? What type of rear do you have? Ford?
03-26-2007, 01:34 AM | #10 |
Truck Enthusiast
12 bolt chev rear end
'85 swb |
03-26-2007, 01:43 AM | #11 |
67 shorty
Do you have a pic of this rear.The reason I ask if the axles are 5 on 4.5 Then it was drilled special by someone.And for you to have the front like this really makes me doubt your conclusion. You need to measure the pattern. Maybe someone can chime in on proper precedure. I think it is center to center (lugs)
03-26-2007, 01:46 AM | #12 |
Truck Enthusiast
im uploading some pics right now.. i know how to measure lug patterns...this is a first for me also. i thought chev trucks were 5 on 5
'85 swb |
03-26-2007, 01:54 AM | #13 |
Truck Enthusiast
what i took off
what i put on rear end
'85 swb |
03-26-2007, 01:59 AM | #14 |
KEEP ON TRUCKIN'
Moser can make you axels in any pattern you want. Give them a call.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
03-26-2007, 02:02 AM | #15 |
Truck Enthusiast
that 12-bolt should have c-clips shouldn't it
'85 swb |
03-26-2007, 02:07 AM | #16 |
67 shorty
C-clips...YES....Thats how I would measure. Thats a little SPOOKY
03-26-2007, 02:09 AM | #17 |
Truck Enthusiast
yup, i should be able to get rotors i hope with 5 on 5. looks like i'll be calling moser also...do you know what spline they are stock? 28? 30?
'85 swb |
03-26-2007, 02:21 AM | #18 |
67 shorty
With your luck,at this point. Iwould count 'em. Goodluck
03-26-2007, 02:23 AM | #19 |
67 shorty
Have you measured the rear? I would if you are going on the fact that the rims match.
03-26-2007, 02:25 AM | #20 |
Truck Enthusiast
i did measure the rears also.. looks like i need to pull an axle and count splines
'85 swb |
03-26-2007, 02:58 AM | #21 |
71 rustless in texas
Actually on all 5 lug patters you measure from the outside of one lug to the center of the opposite lug (skipping one lug) See the attached fitment picture. So using that meathod, your drums are 5 X 4 3/4 which would be correct and your new disc are 5 X 5 which also is correct.
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE Last edited by kbs71; 03-26-2007 at 02:59 AM. |
03-26-2007, 03:58 AM | #22 |
the way youre measureing youre new front discs is wrong, cause youre measureing center to center and its outside to center so that makes the fronts 5 on 5 and if youre rear is the same as the front then you have the right rims for your truck
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
03-26-2007, 07:30 AM | #23 |
Truck Enthusiast
thanks guys!! i guess im just used to measuring 6 lug. this really helped me out.
'85 swb |
03-26-2007, 08:04 AM | #24 |
blood type; Retumbo
your truck had 5 bolt drums on the front?!
03-26-2007, 08:33 AM | #25 |
Happy to be here
It looks like they have been redrilled...
