Old 03-26-2007, 10:46 AM   #1
underdog8704
NCStroker
underdog8704's Avatar
Stuck Wheel, Please Help!
hey guys, i put my stock wheels and tires on my trucks last night to go mess around some, and now i can't get the right rear off. i have sprayed everything down with wd40 real good, but no luck. any opinions or should i just keep poundin on it til it comes off?
1971 Chevy C/10-Built 383 Stroker
underdog8704 is offline   Reply With Quote
Old 03-26-2007, 11:02 AM   #2
topnos
topnos's Avatar
Re: Stuck Wheel, Please Help!
My experience has led me to believe that the pounding might eb the only way to go. However, you might want to work on different ends of the rim when pounding to try and prevent any further binding. In other words, hit a couple of times at one end and turn the tire around 180 and take a couple of hits on that end. Good Luck!
topnos is offline   Reply With Quote
Old 03-26-2007, 11:08 AM   #3
bobthecop
bobthecop's Avatar
A big hammer.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-26-2007, 11:09 AM   #4
3/4tonterror
3/4tonterror's Avatar
Did you remove the lug nuts first?Just kidding.sounds like you bent something,stud maybe.good luck.
3/4tonterror is offline   Reply With Quote
Old 03-26-2007, 11:13 AM   #5
underdog8704
NCStroker
oh ya the lugs, those are those shiny things holding it on right? just kiddin. all the studs look good. its just hung up i guess. thanks for the help guys.
Old 03-26-2007, 11:20 AM   #6
bretcopsey
I had this problem on my old 91 Caprice wagon. The hub center bore in the wheel would hang up on the hub of the rotor. After a couple times of using a block of wood and a 3lb hammer to remove the wheel, I broke out the dremmel and lightly cleaned up both the wheel and rotor- Problem solved.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 03-26-2007, 11:25 AM   #7
67CHIP72
STOLEN
67CHIP72's Avatar
I had the same problem with my rally wheels when they were powder coated. Just relieve the wheel's center with a die grinder so it doesn't hang up. Don't want that problem if you get a flat out on the road.
In Search Of
67CHIP72 is offline   Reply With Quote
Old 03-26-2007, 03:27 PM   #8
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Get the truck back on the ground without the lugnuts, get it up to about 5000 rpm and slam it into R, Should come off then. Just kidding.
I had the same problem. I made sure the truck is sturdy on a jackstand and got underneath and hit the tire while turning it slowly. After a while it came off.
After that I cleaned the hubs up real good and havenīt had a problem since.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 03-26-2007, 04:52 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Install the lug nuts, and turn them one or two turns off the rim, then drop the truck back on the floor. Grab the bed, and start pulling the truck side to side. Get the wife, kids, folks, straingers walking down the street... to help, the more the merrier.
Old 03-26-2007, 07:21 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have one rim that is smaller than the center of the hub.It will fit and snug up but it's a B!+ch to get off.I keep thinking I should mark it since I know it's the one painted white.I think it came from an earlier truck but I don't remember getting it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
