Truck pulls to the right when braking.
Truck pulls to the right when breaking. Does anyone know what could be causing this?.
Re: Truck pulls to the right when breaking.
Sounds like right brake is grabbing or the LF is not working. What kind of vehicle? Have also seen rear brakes out of adjustment cause same problem, disk or drum front??
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
It's a 71 C10, It has Disk brakes up front and drums in the rear. I just installed new pads up front, and had them cut the rotors. The rear brakes were checked and they needed to be adjusted. I'm wondering if they need more adjustment.
I was also told that aligment could also cause this problem, but I dont think that the aligment is really that bad, it does pull very little to the right when I'm on the freeway. When I brake is when you can feel it the hardest, I literally have to hold on to my steering wheel when I brake. |
Can also be alignment, my wife is a service advisor at a chevy dealership, they had one in last week, same problem, pulled hard left when brakes were applied, after replacing rotors, brake lines and checking everything, including adjusting rear brakes, it was the alignment, this was on a 1996 Z71, I would adjust rear brakes, make sure the front pads have seated, and do an alignment, before I started replacing parts.
Cool thanx, I was thinking about swinging by the alignment shop after work. I'll do that before I start replacing parts.
AttentionDeficitDisorder
if it is pulling to the right only when you are braking, i would check your left front brake line, im guessing the rubber line might be pinched somewhere not allowing fluid to get to that left front caliper causing only the right side to grab and pull you sideways. just my 2 cents.
