03-26-2007, 12:39 PM | #1 | |||
Union Electrician
back spacing question
I need to know if 5.5" back spacing on a 17" rim is too much for out trucks?I think the rear would be fine,but I am worried about the front and have found a smokin deal on some wheels, but do not know if they will work or not... TIA...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
03-26-2007, 05:25 PM | #2 | |||
Union Electrician
Re: back spacing question
ttt
03-26-2007, 05:38 PM | #3 |
Watch out for your cornhole !
Here's what I know...
a 17x8 with 5 inch backspace works on a lowered truck. In the back, the tires are 275/60/17, which is quite wide and they clear the bed fine. With the extra 1/2 of b.s. you'd want to run a tire that didn't bulge off the rim too much or it would rub for sure.
03-26-2007, 07:17 PM | #4 |
My first thought would be that is too much positive offset (assuming 8" wide wheel). you're only going to have 2.5 inches on the other side of the rim. Might look a little funny with it tucked that far into the wheel well.
How wide are the wheels you are looking at.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 03-26-2007 at 07:19 PM. |
03-26-2007, 07:27 PM | #5 |
Byrd,
Is it a stepside or a fleetside? There is a difference, ask me how I know. Also, rearends from 67 to 70 are not the same width as the 71 - 72s. On the front, I'm using 4.5" back space with 255/60R17 and they fit perfect. Here's a shot from the back with 5" B.S. and 285/60R17s on a 9.5" wide rim I'd say 5.5" would fit better with no chance of rubbing, but real close to the inside of the box. That being said, a 5" back space on a 71-72 fleetside would fit perfectly. Pete Last edited by Shock_Me; 03-26-2007 at 07:32 PM. |
03-26-2007, 09:34 PM | #6 | ||||
Union Electrician
Yes they are 8" wide
03-26-2007, 09:35 PM | #7 | ||||
Union Electrician
67 fleetside, but it has a 71-2 rear end.
03-26-2007, 10:23 PM | #8 | |
So do you have a ealier rear end or is it the later wider rear axle?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
03-27-2007, 06:05 AM | #9 |
It's a 71 rear axle. Right now if the truck bottomed out, the tires would probably rub. We will probably change the back rims to a 5.5" backspace to avoid this.
03-28-2007, 05:58 PM | #10 | |
I wish there was a store around here to "try on different set ups" I am going to try 18" rims with the 275/35/R18 Dunlops sp sport8080E I guess 4.5-5 BS no sure yet.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
