67 shorty
One pc. drive for my SWB
Does any body know if there is a stock driveline that I can pickup at the wrecking yard that will fit in my 67 SWB w/ a 327 and TH400.
67 SWB with enough parts to build two ![]() |
67 shorty
Re: One pc. drive for my SWB
I know I read a thread awhile back about using a stock length drivshaft.Now I can not find it.
I remember one a while back about custom making one - guys taking out the carrier bearing. I don't remember a stock one fitting just right.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
With V-8 engine in the Fwd Mts I think it is 60 " in length. If not I will also be buying cutting and welding some in a couple of weeks. Surely someone will confirm this.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Senior Moment
![]() Join Date: Mar 2002
I had mine made. $200 with ALL new parts and a garuntee. Works perfect.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
There are too many variables to say for certain the right length. It depends on which frame stands you're using and which length of tailshaft trans you have.
You need to measure your application to be sure you don't waste money on something that you can't use.
