Any 2wd lifts out there?
It seems I read about drops all the time and parts for them are easy to find. I've been looking around the web lately for a few inches fo rmy 2wd 3/4 ton.
Has anyone tried it or come across any lifts in their travels around the web? Last edited by Snew; 03-26-2007 at 03:07 PM. |
Rottenwood Garage Member
Re: Any 2wd lifts out there?
Fabtech?
check out ebay for coil spring spacers for the back or make your own.. and the front coils are out there...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
I checked fabtech. They only do newer trucks. I have a cross menber, spindles and upper and lower control arms off a 78 that I was going to use to convert to discs but before I did the deed I wanted to check my options and fix as many of my issues at one time. I haven't even seen much for that era truck. Apparently I need an 88-up.
I haven't seen the taller front coils. I have a leafspring rear end so that end is not an issue. I was hoping for something that may give me a bit more articulation. This thing doesn't flex at all and I can get one tire off the ground pretty easily. It's always in the rear and I'm stuck. Maybe I should get a xfer case and an axle and make it a K20. |
I am a Referee of life.
You might do a search on pre-runner sites.That's a 2 wd off roader.They should be able to give you some ideas.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
turbo enthusiast
1 ton springs would lift the front a few inches higher
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
I had 1 ton springs on my 70 3/4 and old school ball joint spacers on the front, i ran,33s all the way around with no rubbing. i got pics if i can find them
I would like to know more about your setup and to see some pics 3/4 ton terror.
