well i set up another set of heads this last weekend
for my buddy don's 400 engine.. thought i would share... lapped the valves springs seals locks retainers ******drilled the steam holes****** 500 lift ...very easy job anybody can do it bought the springs, locks, retainers, on ebay check this out http://cgi.ebay.com/ebaymotors/550-L...mZ180096366601 there giving the stuff away ![]() ![]() heres some pictures Last edited by rage'nrat638; 07-12-2007 at 06:55 AM. |
these work on any stock head that was on our trucks
327, 307, 350 you can do this with the heads on to guy's or with them off compressor tool with the heads on engine http://cgi.ebay.com/ebaymotors/NEW-U...QQcmdZViewItem heres the compressor tool with heads off http://cgi.ebay.com/ebaymotors/8-AUT...QQcmdZViewItem Last edited by rage'nrat638; 07-12-2007 at 06:55 AM. |
Re: Installing Z28 Valve Springs On 882 Heads
got questions feel free to ask. p.m. me if you like.
to do this on the engine you need to rotate the engine until each cyl has both valves closed and charge the cyl with air.. to hold the valves closed. i know theres a lot of guy's with tired springs and shot valve seals out there heres the tool to charge the cylinders with air http://cgi.ebay.com/ebaymotors/NEW-A...QQcmdZViewItem you can even check your cyl compression with that tool you will really be a fly guy then ![]() Last edited by rage'nrat638; 07-12-2007 at 06:55 AM. |
#4 | |
GEARHEAD
Wondering... That one picture shows a black umbrella seal on the valve in the second groove, and the rubber o-ring down to the guide. I thought the o-ring went in the groove and the seal set down to the guide??
Robert
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ |
#6 | |
here's some pictures of the parts i just pulled off the old heads..
i found one cracked valve.... and you can see the difference in the spring heights. YOU DON'T NEED A SPRING TENSION TESTER TO SEE THIS so if your ever wondering why a tune-up just don't do it.. and you've stripped all the screws on your carb trying to make it run better.. check out the valve's and seals they might just tell the story heres some pictures cracked valve shot springs rock hard seals, crumble in your hand Last edited by rage'nrat638; 07-12-2007 at 06:55 AM. |
