Hello
im new to this site im from San Antonio, Texas and i got a long bed 68 chevy c 10 and i have been restoring it lil by little, anyhow i was wondering if anyone could give me some tips on replacing my inline six engine with a 350 and what kind of parts do i need to adapt to my mannual tranny, thanks for any help, AND IT WILL GREATLY would be appreciated
Designated A-hole!
Re: Hello
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Truck Enthusiast
Re: Hello
welcome from WA
'85 swb |
Always Fixing Things
Re: Hello
Welcome. What kind of transmission are we talking about?
Just an Average Joe ![]() ‘68 GMC 307 3spd – My dad's original truck 310,000 miles |
Its always something!
Re: Hello
Welcome from FT Worth.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() ![]() Member of the patina club |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Re: Hello
Welcome To The Boards From The Great White North!
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
Re: Hello
Welcome to the board from New zealand
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
Re: Hello
Welcome to the board from Maryland!
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King |
On the fast track to nowhere..
Re: Hello
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
Re: Hello
Welcome from Deer Park Tx
Re: Hello
Welcome from Oklahoma
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
Re: Hello
Welcome from East Texas!
1969 ![]() ![]() |
#13 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Hello
Assuming that you're going with a pre-1987 350 engine, it's quite an easy swap.
The flywheel off your inline 6 will bolt to the 350 as long as it's a 250 inline and not a 292. A 292 uses larger bolts so the holes will be too large. The starter will work too. Of course since you're reusing the flywheel, you can reuse the clutch and everything straight onto the 350. You can install the 350 onto the stock inline 6 frame stands, again assuming you don't have a 292 six in it now. You'll unbolt the rubber motor mounts off the 6 cylinder and bolt them to the 350 with the 3 supplied holes on the 350 block. Everything lines right up. Then bolt it right down onto the inline 6 frame stands. If you have a 292 six, you'll need the right side frame stand from a 230 or 250. You'll have to fabricate a longer rod to connect the pedal arm to the carburetor. The six cylinder one will be too short. I've done the swap and reused the 6 cylinder radiator. If it's a healthy radiator, you can likely get away with running it. I didn't use a fan shroud either. Definitely try it before you pony up the cash for a bigger radiator. You'll have to slightly lengthen the alternator wiring as the V8 alternator position is higher than the 6 was. You can reuse the six cylinder clutch linkage with two mods. 1) You'll need to slightly narrow the linkage with a hacksaw as the V8 sits closer to the frame than the inline bracket did, so the Z bar will be slightly too wide. Usually, 1/2" will do it.Just trim the end closest to the engine. 2) You'll need a screw in pivot ball for the V8 block. GM muscle cars used them, so they're easy to find. Mine came off a 66 Chevelle. It's a real easy one day job. I swapped my six cylinder back and forth for a 350 several times last year (long story). This is the easist way to do the swap. It doesn't require any driveline modifications or anything like that. If you go with the factory V8 frame mounts, it will move the engine and trans about 3 inches forward, so driveline will need to be lengthened. Any more questions, just ask.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 03-27-2007 at 01:16 PM. |
#14 |
Re: Hello
thanks that really answered alot for me, i really aprecaite it
#15 |
Re: Hello
Welcome!
R.I.P. Killer 71 10/26/07 |
#16 |
Re: Hello
Welcome to the board. There are PLENTY of knowledgable people that will help steer you in the right direction.
#17 |
![]() Join Date: May 2006
Re: Hello
Welcome from Ky
Pickles |
