03-27-2007, 12:03 PM | #1 |
Junior Member
fuel tank help
have a 69 c10 shortwide wanting to move the fuel tank to the back under the bed and i am needing to know a few things my dad is building it out of alum. i want to run the fill neck straight up and not to the side.
what sending unit would i need . best way to vent the tank or what would i need to do for this were could i get a alum. filler neck i know there is someone on here that builds the alum. fuel tanks but i cannot find the info on it anymore any help would be very helpful also i just want to add that this has been the best site by far for getting help and answers that you need when building a project truck thanks to all for having this site and helping keep this site going |
03-27-2007, 12:15 PM | #2 |
Junior Member
Re: fuel tank help
I only know this, and I am sure you will get some responses, but I believe fuelcellguy is the one you are talking about. I agree this is a great site!
03-27-2007, 12:23 PM | #3 |
Re: fuel tank help
yep, fuelcellguy makes them from scratch. I think that you use a 90ohm sending unit.. good luck.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-27-2007, 01:23 PM | #4 |
Re: fuel tank help
With all the SWB swaps, I have to wonder, is there room to put a tank above the driveline, just behind the cab and under the bed in a LWB? It would be nice to jut run the filler upper to the stock location.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
03-27-2007, 02:13 PM | #5 |
Questionable
Re: fuel tank help
Any 90ohm sending unit should work. www.tanksinc.com
Lots of parts there, and even more accessories on the accessories page (Link: http://www.tanksinc.com/index.cfm/pa...=cat/cat62.htm )
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-27-2007 at 02:14 PM. |
03-27-2007, 10:06 PM | #6 |
Re: fuel tank help
classic performance products shows some measurements for an aluminum
gas tank on page 58 of their catalogue. a square tank would be 9 inches deep, 19 and 1/4 inches long and 27 and 1/4 inches wide. they show a slope of 2 and 3/4th inches from front to back. I assume for exhaust clearance coming over the axle. They also show some bed fill gas fill necks. Also early classic enterprises website has a nice tech article on mounting under the bed tanks. Hope this helps, poco. |
