Old 03-27-2007, 01:27 PM   #1
jlaird
jlaird's Avatar
move crossmember forward?
Isn't the wheel not centered in the fender when these trucks are at full dump? The wheel moves back toward the cab right? Has anybody moved there crossmember forward to correct this? If so, how much?
jlaird is offline   Reply With Quote
Old 03-27-2007, 07:49 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: move crossmember forward?
Porterbuilt's DropMember is an inch, I think. You're talkin' bout a lot of work to use the stock steering linkage. Rack and pinion would make this much easier. Looks like you might get to be the first...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-27-2007, 09:09 PM   #3
jlaird
jlaird's Avatar
I don't know about the rack. I've been Pm'ing porterbuilt about it and it seems it is more complicated (suspension geometry wise) than I had thought.
Old 03-28-2007, 01:05 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
It can be complicated... the hard part is making/finding the room to fabricate the mounts for the rack, and getting it in the right location. Fractions of an inch can have a large effect on the steering geometry. There's a reason nobody makes a kit for a 'simple' rack and pinion conversion on these trucks! It can be done, just a lot of planning, a lot of research, and a lot of patience. Anybody could fab some mounts for a rack and pinion and slap it on there... getting it work "right" takes a bit more.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-28-2007, 07:29 AM   #5
jlaird
jlaird's Avatar
See what i mean......I'm running for the hills!!!
Old 03-28-2007, 03:19 PM   #6
Alvin
Never Done?
Alvin's Avatar
Slammed67 fixed his truck a different way.
Visit his site (http://www.jayspot.com).
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 03-28-2007, 04:03 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
That's pretty sweet, but I wonder what the new tie-rod angles do to the performance?
Frizzle Fry is offline   Reply With Quote
Old 03-28-2007, 05:09 PM   #8
jlaird
jlaird's Avatar
Oh yea, I forgot about that dude. He did some pretty cool stuff. At one point, he said he modified the upper arms,but he doesn't say what he did. Anybody know?
"These pictures show the modified upper a-arm ends. With the a-arms in this "low" of a position, the ball joint angles were way off. Now at ride height (as shown in the pictures), the ball joint studs are centered in the joint which will allow a full range of travel without binding."
Old 03-28-2007, 06:10 PM   #9
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Maybe he raised part of the arm where the ball joint bolts on the side closest to the frame to level it out some? It's hard to tell but there doesn't appear to be as much of a curve on the outboard area of the arm as there is on a stock piece.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-28-2007, 06:42 PM   #10
jlaird
jlaird's Avatar
oh yea, I see that. You may be right. It looks like he something was possible cut, welded, and then ground smooth.
I've also read a couple times of people flipping the uppers arms and moving them on opposite sides of the vehicle. Never seen pics of that though.
I think I'm just going to get ART uppers. My uppers need to be rebuilt at a cost of about $150. For another $150 bucks, I can just by the ART uppers.
Old 03-30-2007, 02:50 AM   #11
BigSky71
LAIDOUT
BigSky71's Avatar
I have heard of that on big cars, but haven't seen it on a C-10 either...
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-30-2007, 08:18 AM   #12
jlaird
jlaird's Avatar
yea, I've read about here, but never seen it.
Maybe it's one of those c10 urban myths!!
Old 03-30-2007, 10:09 AM   #13
BACKYARD88
BACKYARD88's Avatar
I've read about this here also. I'm gonna try it on my truck, if ti doesn't work I can flip it back.
-Mike Owen-
Old 03-30-2007, 12:17 PM   #14
Jaredm82
Active Member
Jaredm82's Avatar
I \t works, I bolted them up like that before because I heard the same thing. You don't get full lift because the arm hits the crossmember before its all the way up. You could just cut out part of the arm to male it work but I wouldnt. Plus i think it looks really weird. Its very obvious they arent on right?...
Jaredm82 is offline   Reply With Quote
Old 03-30-2007, 01:12 PM   #15
BACKYARD88
BACKYARD88's Avatar
That was my only concern. If there isn't a way to plate it so it looks better I will just modify the way the ball joint sits in the arm.
-Mike Owen-
