I have a question about my truck, and I was hoping someone could point me in the right direction.
I own a 1970 c-10 with a 307 c.i. v8 and automatic. My question deserves some history first. About 6 mos ago, I went out to the truck and turned the ignition key and for the first time I got NOTHING in response. As most of us already know, this could be the start of something bad. I proceeded to do absolutely nothing in terms of fixing the truck because from that point on if I just turned the key enough the solenoid would engage and the truck would turn over. Each time I did this though it took longer. I just figured it was the starter / solenoid so I'll unhook the battery, then the ground on the starter, then the power wire with the two mounting bolts and replace the whole unit at once and its fixed right.....NO ! ![]() ![]() |
Re: Could use some help??
I have the same problem, but I figure it's my switch because if I bridge the poles in the starter it turns over just fine
Thanks, Jere '72 Cheyenne LWB, Dark Olive.. gone. Others02 Sienna XLE, 1998 Mercury Tracer Past in order of exit 04 xB RS1, 04 xB BCP, 87 Sciorrco, 97 Safari, 95 Contour, some dodge stratus, 87 Nova notchback, 87 Nova 5 door, 84 Z28. 81 C10 LWB 305 http://www.elmiradhc.com/ http://elmirahockey.com/ |
Active Member
Replace the switch. They are easy to replace. The hardest thing is getting the connector off the switch.
Sonny New Project: 67 Small window SWB 2006 Crew Cab Silverado LT ![]() ![]() |
Sounds like just a bad ignition switch.
![]() ![]() ![]() 67 C10 SWB 350-Turbo 400 tranny-Disc brake "Those who live by the sword get shot by those who don't" |
Scrapper 1
and one other thing when was the last time you had your starter tested and when was the last time you changed your battiery cables
laying low
![]() Join Date: Mar 2001
Have you tried wiggling the shift lever a little bit while you have the switch turned to start? This could very well be just a well worn neutral safety switch which is mounted on the lower end of the steering column. The starter circuit runs through that switch, (the big purple wire). Wiggling the shift lever a bit may line up the contacts in the switch or you could unplug the purple wires from the switch and put a jumper wire in them and try to start it. If it starts you have a bad safety switch or it just needs some adjustment.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Good points felow members.
#9 | |
#10 | |
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
I'd say try your control module. Its in your ditributor under the rotor if memory serves me right. They are real cheap, like less then 10.00 bucks. Also you might want to have your battery tested, it may not be putting out enough cranking Amps. Just a few i deas.
I'm no expert by any means but i dont think its your switch if its turning over. Sounds like a power issue. -Good Luck.
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 03-28-2007 at 02:34 PM. |
Active Member
You can buy the ignition switch from just about any parts store. You can reuse your original tumbler. If you want to replace your tumbler and key you can pick them up at just about any parts store too. The ignition switch (GP Sorensen S55 $14.44) and the tumbler and key (AC Delco D1499A $10.88) are pretty cheap from Advance Auto Parts. Yeah, I would check the neutral safety switch too. I have the Hurst shifter in my truck and the purple wire is jumpered. Good Luck finding your trouble!
#13 |
It might be good to think about what's happening (or should be) when you turn the key to start the truck.
The ignition switch provides power to the starter solenoid, which in turn provides power to the starter motor to turn the engine. Since you say 'nothing' happens when you turn the key, and after messing with it, it starts, the problem is probably in the ignition switch and solenoid circuit. The started motor isn't involved yet... There are 2 wires running to the starter solenoid combination. A large one directly from the hot side of the battery to run the starter, and a smaller one to the solenoid to engage the solenoid. The ground is provided by the starter being bolted to the engine, which should have a good ground. There is no ground wire to the starter, or solenoid itself that I know of. You might try running a temporary ground from the negative battery post to the starter. Now try to start it. If it works correctly, its a bad gound. You might also make a long wire with alligator clips on both ends using #12 or #10 wire. Now connect one end to the small wire on the solenoid, crawl out from under, then touch the other end to the battery positive terminal. Have it in park, the E-brake on, etc. when you do this! If the starter turns as desired, the problem is in the ignition switch circuit. Possibly a bad switch, loos wire, etc. The good thing about these tests, is that they're cheap, and don't require much effort like pulling the started. My kind of tests. Sorry if I was long winded... |
#14 |
Its Magically Delicious
if the NSS is bad ... then the starter wont turn at all .... right??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#15 |
I am a Referee of life.
Correct.The switch can cause it to not even turn over.
The easiest way I have found to see if the switch is the problem is to unplug the plug on the switch and plug in a new one and try to start it.If it starts then I go to the trouble of installing it in the dash.Just saves problems installing something that may not fix it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#16 |
You can check hot wire at starter with key on with volt meter need 12v.
Mine did this and was getting only 1.5 volts wire was broke but hard see because insulation on wire was still ok. Good Luck..
