03-27-2007, 04:41 PM | #1 |
any info on a SUPER rare truck i'm going to look at?
what the seller has told me
1970 C/30 AC cab Dually longhorn camper special flat-decked frame walk-thru cab anyone have any details about this bad-boy? how rare is it? are these factory options? or is it a custom job?
RN U OVR |
03-27-2007, 04:44 PM | #2 |
Re: any info on a SUPER rare truck i'm going to look at?
sounds like a uhaul truck
03-27-2007, 04:53 PM | #3 | |
No,never was a dually with a longhorn bed made
03-27-2007, 04:57 PM | #4 |
only on longbeds?
what about the flat-decked frame? is that normal?
RN U OVR |
03-27-2007, 04:59 PM | #5 |
Maybe I should state that there was never a dually made in 67-72 with a pickup bed( stepside or fleetside)
As for the frame,dont know Last edited by 1969k10stepside; 03-27-2007 at 05:00 PM. |
03-27-2007, 05:08 PM | #6 |
i was wondering about that... i never saw a dually. i was dreaming of some sort of eaton dually rear axle.
is there any way to identify a 1 ton frame? i have only been up close and personal with my 1/2 ton frame. the main reasons i'm interested are 1. possibility of a beefier frame 2. dually rear 3. flatdecked frame so... #2 is questionable what about #1 and #3?
RN U OVR |
03-27-2007, 05:11 PM | #7 |
TOTY 2006
Sounds like this was a motohome.
(being a dually with the walk thru cab) What does he mean by flatdecked frame? Is it now a flat bed? Last edited by John Fabris; 03-27-2007 at 05:11 PM. |
03-27-2007, 05:13 PM | #8 |
Dually were made, just not with a bed. He may be calling it a longhorn due to the long frame. I passed on a motor home dually. It sounds legit, just the seller is not up to par on the terminology? Go look and see what you think, besides "rare" in the truck world still isn't muscle car rare!
03-27-2007, 06:16 PM | #9 |
Thats what my cab looks like, it was a motorhome. If it has the cutout, then probably was a motorhome. The flat bed might just be the floor of the camper, or someone made a flatbed?
03-27-2007, 07:33 PM | #10 |
that's the truck! i think i'll cut the rest of the back out and run the cage from the cab out the opening onto the flatbed.
the dually IS an Eaton dually... but unless it's an HO110, i don't think i'll use it. i didn't realize the C&C dually would be a narrower WMS-WMS. i need a full width dually rear to run my HumVee wheels at the same width as my dually front axle. does anyone know if the 1 ton frame is more stout than a 1/2 or 3/4? thanks for the pics! and the info!
RN U OVR |
03-27-2007, 07:48 PM | #11 |
Yes - the 1T frame is taller than the 1/2 or 3/4. The channel is 1 inch taller if I recall correctly. The front portion of the 1T is the same dimension as the 3/4 and gets taller somewhere around the down sweep near the front cab mount. I think it's more of a fact that the frame gets lower. I think the top profile stays the same as the 3/4 frame but the bottom hangs down an extra inch. The automatic transmission crossmember requires a spacer to bolt to both surfaces of the frame. I assume the taller frame continues all the way to the rear.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
03-27-2007, 07:52 PM | #12 |
Scrapper 1
that frame would work as a nice weacker with one of them steel beds with a dove tail with Rollers and a winch at the front of the cab thats what i'm looking for
03-27-2007, 10:48 PM | #13 |
Here`s the`70 CustomCamper/30 I bought with the camper (Winnebago) removed.Iwas lucky it wasn`t a pass-through.It did have snap fasteners around the window opening.It was loaded with 402,TH400,a/c...
03-28-2007, 03:01 PM | #14 |
make it look like this but a Chevy...
Mike Currents: '74 Cheyenne Super C30 Camper Special 3+3 aka "Sucia30" Past: '79 C10 BIG 10 (Sold) 69 CST LWB - Always a "Work in progress" true work truck (stolen) 05 GSXR 750 it has a pretty paint job _wrecked 72 SWB full frame restoration -sold! 71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold! C10 Club 2012 Brothers Show Video http://youtu.be/pUeV2vP7Wpo |
03-28-2007, 09:32 PM | #15 |
ABSOLUTELY NOT!
what it's getting (from my donor K/10): 1. custom 52" long front spring suspension. 2. Shackle flipped 63" long rear spring suspension. 3. 7" black widow shackles. 4. offroaddesign larger spring hangers. 5. high pinion Dana 60 front axle. (dually) 6. either- sterling 10.25 or 14bolt Full Float rear axle. (both dually) 7. NP205. 8. H1 8-bolt wheels. 9. 42" swampers up front. 42" boggers, rear. What i'm going to add: 1. 7.3 powerstroke turbo. 2. Flatbed. 3. Toolbox. 4. Winches. 5. Crossover steering. 6. Full cage tied into the flatbed via a GIANT GAPING HOLE in the cab (i'm going to cut the entire back of the cab out... how's that for your ) 7. rattle can black paintjob
RN U OVR |
03-28-2007, 09:38 PM | #16 | |
This thing is in absolutely gorgeous shape. i'm just waiting for the current owner to pull the motor and tranny (the reason he bought it) and i'll take it into posession. i went and looked at it today, and i'm SERIOUSLY impressed with the beef of this frame. just from some overall looking, it also looks like the frame is made with thicker gauge steel.
RN U OVR |
03-28-2007, 11:18 PM | #17 |
There's a fellow in town here that made a flatbed out of an Open Road RV , works great , looks a little funny to me with the long cab to axle length, but he works the crap outta it .
409
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
03-29-2007, 05:40 AM | #18 |
My`70 was super clean east coast sheetmetal.too.Who goes camping in the salty winter?Or,even in the rain if it can be avoided?The only winter driving would be to head for the sun.Also,for a big one ton it`s never been worked or had employees rumping it.With that body RV body and stuff hanging and things on shelves,bumps and twists were handled very gently.These make for some of the tightest survivors out there.
03-29-2007, 11:35 AM | #19 | |
The motorhome Eaton duallys are HO-72's, the HO-110 would have 10 wheel studs and are found under the big grain trucks and such. Last edited by Americanrider; 03-29-2007 at 11:37 AM. |
03-29-2007, 03:48 PM | #20 |
Saving 1 truck at a time!
Love those duallys! They were 157" wheelbase as well.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
03-29-2007, 04:08 PM | #21 | |
Special K wrote:
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
03-29-2007, 04:28 PM | #22 |
for those who pull up this thread in a search for "eaton axle" or "C/30 dually" or something:
1. aside from being having 10 lugs (i'm not sure of that. just repeating what AmericanRider stated) the eaton HO110 also has a welded on dif cover. 2. the C/30 i bought has a VERY RARE bowtie Turbo400 tranny with straight cut gears, and NO PARK! these things are worth their weight in gold to hot-rodders
RN U OVR |
03-30-2007, 01:44 PM | #23 |
American Rider - thanks for correcting my mistake. I will try and file that away for future use. I knew that they were taller just not how much.
03-30-2007, 06:23 PM | #24 |
Hey Senator350,my`70 had that TH400 w/no park.Here`s a picture in the background when I first bought it with the camper off...
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-30-2007 at 06:39 PM. |
