Old 09-04-2002, 08:12 AM   #1
PitterPats72
Question Engine "gulp"
Was driving the 72 from the airport last night when I noticed I was going about 72 mph. I really didn't want to be going that fast so I let off the gas a bit. My engine took like 2 big gulps or coughs or you might say misses. I've had this happen before when I was giving it the gas but never when Iwas letting off the gas.
Any ideas why? I do have an HEI and a 4bbl Q-jet.
Thanks in advance. Pat
72 Chevy Custom 10 Deluxe (78K mi.)
95 Nissan Maxima (195K mi.)
73 VW Beetle (owned since 78; 96K miles) Engine rebuild by me done!
73 VW Super Beetle -New to me- Bought from original owner!
84 Honda Nighthawk (2500 mi.)
I know too much foreign stuff; I've owned American too and they lasted
just as long.
PitterPats72 is offline   Reply With Quote
Old 09-04-2002, 02:54 PM   #2
PitterPats72
TTT
just as long.
Old 09-04-2002, 04:03 PM   #3
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
im no expert at this stuff at all, but do you know if your timing is all good?
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 09-04-2002, 05:59 PM   #4
COBALT
COBALT's Avatar
This only happens when you let off the gas? What about when you stomp it at a light or something? Does it hesitate or pop?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-04-2002, 11:54 PM   #5
PitterPats72
new69owner
Last night was the first time it happened when I let off the gas. But it has happened before when I am giving it gas.
Pat
just as long.
Old 09-05-2002, 04:00 PM   #6
wcdrake
I dont know if this is the same thing but my 72 started doing this. It would do it once in a great while and when it did it was only a quick sputter. I continued to drive it and over the course of the summer, it would sputter when you were not expecting it. Here about a month ago, we were heavily loaded with camper and trailer when it coughed and then let out the most ferocious back fire. I was thinking there may be moisture under the cap and in doing so noticed the cap was very corroded. I replaced the cap and runs like a top and have not had any hiccups since. Good luck
wcdrake is offline   Reply With Quote
Old 09-05-2002, 04:30 PM   #7
COBALT
COBALT's Avatar
IGNITION!!!! Sounds like you need to inspect your cap, rotor, and points. You may have to haul out the feeler guage and dwel angle guage. Good luck.
Seattle, WA.
