Production Numbers in an Excel Spreadsheet
I put the 67-72 production numbers that are posted around the internet into a handy Excel spreadsheet for the forum. It is listed by Year and Production Total but you can use the Excel Database feature to sort the data in whatever order you are interested in. Kind of fun to mess with and see what some of the rare combinations are. (Be aware that some errors in this data have been identified, any corrections anybody wants me to make let me know).
So, for example, if you wanted to know what the rarest SWB 4x4 Step-Side is you would click on Data, Sort, then choose Drive, Body, and Production Total. Here's the result : Year Capacity Drive Model/Series Wheelbase MODEL BODY TYPE PRICE WEIGHT PROD.TOTAL 1971 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10904 Step-Side 8ft 3451 3832 364 1972 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10904 Step-Side 8ft 3287 3846 407 1970 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10904 Step-Side 8ft 3158 3715 464 1967 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10904 Step-Side 8ft 3051 - 500 1969 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KE10904 Step-Side 8ft 3085 3651 521 1968 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KE10904 Step-Side 8ft 3022 3916 552 1971 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10904 Step-Side 8ft 3804 4061 674 1972 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10904 Step-Side 8ft 3567 4051 755 1970 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10904 Step-Side 8ft 3502 4006 953 1968 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10904 Step-Side 8ft 3163 3940 1047 1969 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10904 Step-Side 8ft 3315 4025 1071 1967 1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b KS10704 Step-Side 6.5ft 3013 - 1229 1971 1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b KS10704 Step-Side 6.5ft 3414 3739 1438 1970 1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b KS10704 Step-Side 6.5ft 3090 3631 1629 1969 1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b KE10704 Step-Side 6.5ft 3047 3652 1698 1968 1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b KE10704 Step-Side 6.5ft 2985 3771 1706 1972 1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b KS10704 Step-Side 6.5ft 3251 3766 1736 Cleaned up a bit: 1971 1/2-Ton 4x4 Step-Side 8ft 364 1972 1/2-Ton 4x4 Step-Side 8ft 407 1970 1/2-Ton 4x4 Step-Side 8ft 464 1967 1/2-Ton 4x4 Step-Side 8ft 500 1969 1/2-Ton 4x4 Step-Side 8ft 521 1968 1/2-Ton 4x4 Step-Side 8ft 552 1971 3/4-Ton 4x4 Step-Side 8ft 674 1972 3/4-Ton 4x4 Step-Side 8ft 755 1970 3/4-Ton 4x4 Step-Side 8ft 953 1968 3/4-Ton 4x4 Step-Side 8ft 1047 1969 3/4-Ton 4x4 Step-Side 8ft 1071 1967 1/2-Ton 4x4 Step-Side 6.5ft 1229 1971 1/2-Ton 4x4 Step-Side 6.5ft 1438 1970 1/2-Ton 4x4 Step-Side 6.5ft 1629 1969 1/2-Ton 4x4 Step-Side 6.5ft 1698 1968 1/2-Ton 4x4 Step-Side 6.5ft 1706 1972 1/2-Ton 4x4 Step-Side 6.5ft 1736 Enjoy, Jerry |
67 is sold
Re: Production Numbers in an Excel Spreadsheet
Nice. Any chance you have the numbers for Panels, burbs and Blazers?
Here ya go. They are all in there.
Year Capacity Drive Model/Series Wheelbase MODEL BODY TYPE PRICE WEIGHT PROD.TOTAL 1971 1/2-Ton Blazer 2WD - Model C/Series 10 - 104-in. w.b. CS10514 Open Utility 2659 3375 1277 1972 1/2-Ton Blazer 2WD - Model C/Series 10 - 104-in. w.b. CS10514 Open Utility 2585 3375 3357 1969 1/2-Ton Blazer 4x4 - Model K/Series 10 - 104-in. w.b. KE10514 Open Utility 2852 2947 4935 1971 1/2-Ton Blazer 4x4 - Model K/Series 10 - 104-in. w.b. KS10514 Open Utility 3234 3677 17220 1972 1/2-Ton Blazer 4x4 - Model K/Series 10 - 104-in. w.b. KS10514 Open Utility 3145 3677 44266 1970 1/2-Ton Blazer 2WD - Model C/Series 10 - 104-in. w.b. CS10514 Open Utility 2385 3375 NOTE: 4×2 (both E and S) production = 985 1970 1/2-Ton Blazer 2WD - Model C/Series 10 - 104-in. w.b. CE10514 Open Utility 2852 2947 NOTE: 4×2 (both E and S) production = 985 1970 1/2-Ton Blazer 4x4 - Model K/Series 10 - 104-in. w.b. KS10514 Open Utility 2955 3677 NOTE: 4×4 (both E and S) production = 11527 1970 1/2-Ton Blazer 4x4 - Model K/Series 10 - 104-in. w.b. KE10514 Open Utility 3050 3807 NOTE: 4×4 (both E and S) production = 11527 1967 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KS10905 Panel 3286 - 8 1967 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10905 Panel 3422 - 30 1968 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KE10905 Panel 3393 4123 59 1968 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10905 Panel 3534 4111 68 1967 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20905 Panel 2884 3917 940 1970 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20905 Panel 3269 3991 1032 1968 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CE20905 Panel 2981 4035 1572 1969 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CE20905 Panel 3172 4093 1779 1967 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10905 Panel 2742 3502 3827 1970 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10905 Panel 3040 3730 3965 1968 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CE10905 Panel 2839 3641 4801 1969 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CE10905 Panel 2960 3724 5492 1969 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KE10905 Panel 3513 3935 - 1970 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10905 Panel 3641 3923 - 1970 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10905 Panel 4019 4221 - 1968 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CE20909 Stake 8ft 2702 4085 1103 1967 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20909 Stake 2606 3973 1415 1967 1-Ton Commercial 2WD - Model C/Series 30 - 133-in. w.b. CS30909 Stake 2875 4390 3236 1968 1-Ton Commercial 2WD - Model C/Series 30 - 133-in. w.b. CE30909 Stake 2971 4499 3272 1969 1-Ton Commercial 2WD - Model C/Series 30 - 133-in. w.b. CE30909 Stake 3063 4617 - 1969 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CE20909 Stake 8ft 2832 4138 - 1967 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KS10906 Suburban 3850 - 120 1967 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban 3666 3670 166 1968 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban 3611 4215 299 1970 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban 4190 4343 541 1969 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban 4040 4316 545 1967 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20906 Suburban 3170 4093 709 1968 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CE20906 Suburban 3264 4217 1573 1970 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20906 Suburban 3441 4113 2246 1969 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CE20906 Suburban 3447 4199 2736 1968 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KE10906 Suburban 3667 4212 4259 1967 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10906 Suburban 2986 3670 5164 1968 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CE10906 Suburban 3081 3809 11004 1969 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CE10906 Suburban 3194 3815 14056 1969 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban 3749 4024 - 1970 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban 3849 4055 - 1971 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban(doors) 4530 4414 256 1972 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban(doors) 4275 4141 503 1971 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban(doors) 4226 4191 631 1972 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban(doors) 4273 4206 993 1971 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20906 Suburban(doors) 3760 4245 1343 1972 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20906 Suburban(doors) 3650 4245 2136 1971 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10906 Suburban(doors) 3599 3862 4550 1972 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10906 Suburban(doors) 3495 3862 6748 1970 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10906 Suburban(doors) 3250 3862 11332 1971 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban(gate) 4538 4414 353 1972 3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b KE10906 Suburban(gate) 4308 4585 879 1971 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban(gate) 4256 4191 994 1971 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20906 Suburban(gate) 3791 4253 1203 1972 1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b KS10906 Suburban(gate) 4305 4206 2145 1972 3/4-Ton Commercial 2WD - Model C/Series 20 - 127-in. w.b CS20906 Suburban(gate) 3680 4253 3141 1971 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10906 Suburban(gate) 3631 3870 5395 1972 1/2-Ton Commercial 2WD - Model C/Series 10 - 127-in. w.b CS10906 Suburban(gate) 3525 3870 10757 |
