Old 03-27-2007, 05:22 PM   #1
SkylineNXS
SkylineNXS's Avatar
Driveshaft Bearing Replacement
I finally found out today what all that ratling was. I have a 72 with a 2 piece axle, idk if they are all that way, but anyway, the bearing "housing" that bolts to the crossmember is broken right where it bolts on, and i need to replace it. I was wondering if anyone could tell me the easiest way to replace this. I dont want to remove the axle or tranny or anything, but idk if i need to or not. Any help would be appreciated, thanks....
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 03-27-2007, 06:49 PM   #2
SkylineNXS
SkylineNXS's Avatar
Re: Driveshaft Bearing Replacement
Anybody?
Old 03-27-2007, 07:03 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You may be asking about the carrier bearing.If it is the bearing where the two driveshafts meet then that is it.You can unbolt the yoke from the rearend and the bearing where it bolts to the crossmember.The driveshafts should slip out.You may get a little leakage from the tailshaft of the tranny.IIRC the two driveshafts have a bolt that holds the splined yoke into the rear of the front driveshaft.Again IIRC the easiest way to do it is to take out the U-joints to get to the bolt.There are billet bearings available that look super strong.Maybe someone will post a link.Also If I missed something or didn't remember correctly they may give you better info.
One thing Mark the driveshafts so they get put back at the same spline,they are phased.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-27-2007, 07:06 PM   #4
SkylineNXS
SkylineNXS's Avatar
Ok thanks, ill probably do it maybe this weekend, i was just gonna get a replacement from LMC truck, ive got very little money, and there like 20 bucks, not bad. Thanks for the help....
Brad
