manual to power brakes(again)
i know this has been posted before, but i have a manual brakes 69 witha leaky master cylinder, so im gonnag et a new one, then just a booster out of a junkyard, and it should all bolt up right? bend my lines forward a bit and hook up the vaccuum? or am i thinking this is way to easy. i guess my 2 questions are if i get teh 17 dollar rebuilt master cylinder from pronto and a booster off a junkyard 67-72? or what years are bolt on? then it should all go together right? thansk, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
ttt
I think have everything I need to do the same thing, the only thing I can't figure out is how the rod from the pedal attaches to the one on the bell crank thing that is attached to the booster. Does anyone have a picture of what it looks like (not on the truck)?
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
you need to get the rod from the power brake truck too, simplest way.
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft. 1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power. |
WORTHLESS CRUISERS
Hey guys. I just went to power on my 69 with drums. I got a junk yard booster with the mounting brackets, then bought a new master cylinder, found the connecting rod with the pins and everything bolted right up. It's fairly simple. Good luck. Dont forget the vacuum.
Scott Hammond Lancaster, SC 1969 Chevy ![]() If you don't live for something, then you'll die for nothing. www.xclusive-images.com ![]() |
so you want the one that actually hooks too the pedal arm? There was a truck that had the whole thing in pick & pull near my house, so maybe I could get it from that one. Also, the rod on the master clyender looks different. I have 3 one the power brake kind (they were free) but I have never seen one of the manual ones off of the truck.
