Impending doom?
I noticed the circled (below) curl of metal wedged in my fan clutch. It does move around, but it won't come out. I didn't mess with it too much in case it's supposed to be there. Can anyone tell me what it is? I'm concerned that it's part of the fan clutch that somehow lathed itself.
1972 C-20 350 |
Re: Impending doom?
that looks like part of the back of the clutch bearing, might want to look into a fix, flexalite fans are a good deal but fan clutchs aren't bad either
Re: Impending doom?
Id say your clutch is going bad. replacement isnt bad at all. dont bother with flex fans they dont cool worth a darn, and the replacment clutches arent expensive. David
Re: Impending doom?
Can you move your fan front to back very much? Not to insult your intelligence....but make sure the engine is NOT running before you try.
If your fan moves front to back, I'd replace it. But beware, if the bearing has been out in your fan clutch for very long you might want to go ahead and replace your water pump too as the vibration sometimes damages the pump bearing.
-Scott- |
Designated A-hole!
Re: Impending doom?
Looks like a good time to go with electric fans.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: Impending doom?
Thanks for the help, guys. I'll have to check the fan bearing. No insult, sjarrett71. Besides, I'd rather be insulted and still have all my fingers!
I've been looking through the board archives and it looks like a thermal fan clutch is the way to go. Are there any tricks to replacing it or is it just unbolt the old one and bolt on the new one? Yeah, like anything is ever that easy on an old truck.
1972 C-20 350 |
Re: Impending doom?
![]() Join Date: Sep 2005
Re: Impending doom?
i agree about the flex fans they are trouble although i don;t know but my 71 has a solid fan spacer and a solid metal fan that just spend all the time
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Impending doom?
i guess i've had good luck with my flex fan , i made my own shrowd for it so it pulls more than enough but i have heard that if they aren't spaced just right they don't cool very good, as for how easy a fan clutch is to replace they aren't bad for the most part just unbolt
Questionable
Re: Impending doom?
Electric fans work fine. Anyone who tells you otherwise probably has zero experience using them, has never installed one before, installed one improperly before, or knows one or more people who never installed one and/or installed one improperly before.
There are dozens of members here running electric fans with absolutely zero problems. They do the same thing as a clutch-based fan, only they don't tax the engine, so you free up a few horsepower using electric. There is wiring involved, but it is minimal.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#11 | |
Texas Big Wig
Re: Impending doom?
I have some dual electric fans I got out of a salvage yard, & was wondering how close they need to be to the radiator ![]() I know closer would prolly be better, but I'm just curious as to what I could get away with |
Commander Taco Bello
Re: Impending doom?
#13 |
Questionable
Re: Impending doom?
Thanks, Ivel.
One thing about that link and that writeup - some people argue that the product shown in there needs to have holes drilled to allow outside air to pass through the radiator. I don't know why the original manufacturer did not decide this was important - I asked, and the answer given was "never had overheats, even when towing in in the mountains" and I believe it. But ... your results may vary depending on your computeration. Summit and Jegs both sell kits that just bolt to either side of your radiator tanks or similar - pretty simple setups, and they come with fan controls. Flex-A-Lite makes great kits like this! www.summitracing.com -- www.jegs.com
#14 |
Re: Impending doom?
I had a flex fan on my 78, it worked out pretty good.
It had a standard fan with a bad clutch to begin with, so I replaced the clutch, but every time I started from a standing stop the truck sounded like a vacuum cleaner or a turbocharged big rig...WHOOOOOSSSSHH!!!!!!! I had about enough of that so I got a solid spacer and a flex fan. |
#15 |
Re: Impending doom?
I replaced the fan clutch today, and sodak69c10 and TheSasquach were dead on. The clutch bearings were exposed and frozen. I'm looking forward to the increased MPG. Anyway, just wanted to thank everyone and let you know how it turned out.
1972 C-20 350 |
#16 | |
Re: Impending doom?
Public service announcement now over. farmerfred - It's always nice when things go smoothly with no problems isn't it?
2004 Kawasaki KLR Always looking for a cheap driver |
