Old 03-27-2007, 08:18 PM   #1
onelow69c10
Drive shaft ?
I have a laid out (laying frame) 69 long bed and I am breaking carrier bearrings any one put a one piece drive shaft on their truck is this possible or anyone know where I can get a steel carrier bearring?
onelow69c10 is offline   Reply With Quote
Old 03-27-2007, 09:05 PM   #2
jlaird
jlaird's Avatar
Re: Drive shaft ?
If you are breaking carrier bearings, going to a different style isn't going to fix the cause of your problem.I would try to figure out why you are breaking them. Did you adjust the position of the carrier when you put your bags on? You should have. If not, your probably making it and the ujoint operate beyond it's capabilities.
jlaird is offline   Reply With Quote
Old 03-27-2007, 10:29 PM   #3
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
Re: Drive shaft ?
He shoots...he scores!
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 03-28-2007, 07:05 AM   #4
onelow69c10
Re: Drive shaft ?
I bought the truck already bagged the carrier bearing has not been moved I'm just trying to work out all the kinks and get the truck reliable
Old 03-28-2007, 07:27 AM   #5
jlaird
jlaird's Avatar
Re: Drive shaft ?
What you could try (what I did) is rotate the carrier bearing 180 degrees and mount it as high as you can. This will minimize the working angle at that joint in the driveshaft. You will have to do some cutting on the carrier bearing bracket.
Old 03-28-2007, 08:26 PM   #6
onelow69c10
Re: Drive shaft ?
Thanks I may need to try that
Old 03-28-2007, 09:03 PM   #7
jlaird
jlaird's Avatar
Re: Drive shaft ?
heres a pic that will help.
Also read this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=220466
Old 03-31-2007, 01:14 AM   #8
onelow69c10
Re: Drive shaft ?
here are a couple of pics
Old 03-31-2007, 08:25 AM   #9
jlaird
jlaird's Avatar
Re: Drive shaft ?
that looks awesome! We need details. I want to know what you did in the front.
Old 03-31-2007, 03:48 PM   #10
onelow69c10
Re: Drive shaft ?
Thanks but like I said I bought it already bagged but it has 2600 bags up front factory a-arms notched for the steerng and the fron cross member is sectioned 2.5 in it will actuall go about 1 inch lower in the front but I have to get smaller tires tire is sitting on the hood hinge which have already been trimmed.
here is a pic of the notch in the back
Old 03-31-2007, 08:57 PM   #11
jlaird
jlaird's Avatar
Re: Drive shaft ?
Do you have any pics of the front? Would love to see your centerlink and tie rod setup. I've never heard of a 2.5" crossmember notch, but I guess its possible.
Old 03-31-2007, 09:57 PM   #12
onelow69c10
Re: Drive shaft ?
Its not a notch it is sectioned 2.5 inches The truck is at my friends house where we are working on it next time im over there ill take some pics of the front
Old 04-01-2007, 12:23 AM   #13
jlaird
jlaird's Avatar
Re: Drive shaft ?
yea, I meant to say section, not notch. I just finished a 1.5 section on my crossmember. So do you have a rack or stock steering?
Old 04-01-2007, 12:55 AM   #14
onelow69c10
Re: Drive shaft ?
stock the control arms are notched for the steering arm kinda ghetto
Old 04-01-2007, 08:47 AM   #15
jlaird
jlaird's Avatar
Re: Drive shaft ?
how did you prevent the inner tie rod ends from hitting the LCA's?
Old 04-01-2007, 07:20 PM   #16
onelow69c10
Re: Drive shaft ?
LCA? wht does that stand for
Old 04-01-2007, 07:42 PM   #17
jlaird
jlaird's Avatar
Re: Drive shaft ?
lower control arm
Old 04-02-2007, 07:35 AM   #18
onelow69c10
Re: Drive shaft ?
Gotcha I realized that after I typed it but oh well truthfully never paid attention but when I look at it next I'll let you know.
