![]() Join Date: Jan 2007
Asking for your opinion...on buying a 1970 Jimmy
Here is the run down...(taken from the previous owner's description - not mine)
BODY Has been painted once Floors and rear wheel wells are excellent originals with no rot Needs front fenders (used cost approx. $100 each) Right front wheel well is rotted under battery (used: $75) Needs doors (used: $100 – 125 each) Needs tailgate (used: $150) Needs panel over windshield (LMC Truck $100) Bumpers, grille and glass are nice Has some rust around rear wheel openings Left front rocker was installed when I got the truck Right front rocker (shown in photo) goes with truck for you to install INTERIOR Has all original upholstery Dash pad is cracked Needs seat covers and door panels (LMC Truck kit $300) Has Kenwood AM/FM cassette Has aftermarket tach All gauges, heater and wipers work good ENGINE & TRANS Has built 350 Has Crane 290 cam and lifters Has aluma-coated headers and full dual exhaust Has Edelbrock carb and intake Has H.E.I. distributor and Accell Super Coil I gave it a full tune-up and oil change I installed new thermostat and flushed cooling system Has new belts Has top loader 4 speed transmission Has new Interstate battery DRIVE TRAIN Has 205 Gear drive transfer case Has 12 bolt rears I installed new brakes and wheel cylinders all way around I installed new master cylinder and changed to DOT 5 fluid Has new 235/75R15 white letter tires on blasted and painted original wheels Has original hub caps SUMMARY I have worked on this truck to get it mechanically excellent to drive. It runs great; all lights, wipers, etc. work fine and the 4WD will tear a house down. It is not a show truck (see photos) but has a lot of potential. END Previous Owner's description** I am going to check it out over this weekend - what are your thoughts... How tough is it to find used doors, fenders, and a used tailgate...(in somewhat decent shape)? I also see that Goodmark now also stocks the ''over the windshield' repair piece for ~$100 (Goodmark part #4143-495-672) - anybody done this yet? Good or bad experience? Pix ![]() ![]() ![]() ![]() ![]() ![]() |
I'm a poor spectator
Re: Asking for your opinion...on buying a 1970 Jimmy
I'd buy it if the price was right.
So how much???
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
I am looking to spend $2500-$3500 on this Jimmy depending on the condition when I see it.
Is that what he's asking or what you're offering. You might say 2500 and he might be thinking 5500. For what you said, 2500-3500, i'd definitely go for it, maybe even a little more if the motor is as stout as he claims.
SKINNY TIRES RULE!
For every small amount of rust visable, count on an equal amount hidden. It looks pretty rusty to me. I'd guess in the $1500-2000 range. The engine doesn't look original and the power booster on the brakes is missing which makes me suspect some creative parts shopping. It appears to have some AC parts, but not all - yet the listing states that all the heat works. Additionally, the radiator isn't stock, so I'd find out what that one is out of to make sure it can handle the engine.
True Blazer/Jimmy doors are hard to come by used. Double that cost. I'm not sure what the panel over the windshield is, but I don't think LMC sells it. Interior is going to be double that estimate. The used replacement prices seem a bit low to me. It also doesn't include labor to install. Overall, it looks fairly unmolested and would be a good project starting point. '70 Jimmy's are few and far between.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Designated A-hole!
That part won't work on a blazer iirc.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Did you buy it? Looks like it ended early (yesterday) @$3800?
Future TOTM Winner
The rust over the windshield scares me. Isn't that what has made so many guys turn their noses up to otherwise nice tubs? I think it is a pretty hard repair for someone other than a very experience body man. Also, I have been looking for original doors as well and I have yet to find any decent ones for that price. If I had, I would already own a nice set by now! Just my $0.02.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
I asked to come look at it prior to buying and he pulled the auction (with me as high bidder) so that I could come check it out and make a final decision on it.
Keep the comments coming guys - I am sure there are plenty of things to look for on these old rigs and you guys have probably seen quite a bit over the years. Any questions that I should ask specifically on the truck (other than the radiator source and brake booster questions)? I am supposed to talk to him again tonight to figure out some sort of a schedule for the weekend - my GF has family down in that area so it won't be a wasted trip anyway. Last edited by lks dcvn; 03-28-2007 at 07:49 AM. |
You would be $ ahead if you spent twice that amount on a more rust free blazer. Looks too rusty to me but I have to buy my rust work! There were no pics of the interior, that concerns me. I was just lucky when I found mine!
#13 |
Pix over rear wheel wells:
![]() ![]() Thanks guys for your help so far... I was looking for a good running truck that could be used during nice weather (I don't off road) and that could be (somewhat) easily repaired rustwise - The tailgate would be an easy replacement (even using a panel from LMC, tabco, etc.), the doors a bit tougher to find... Last edited by lks dcvn; 03-28-2007 at 08:29 AM. |
#14 |
SKINNY TIRES RULE!
Repop Blazer/Jimmy doors are made now.
In my opinion, $3,000-4,000 is way, way too much for that rig. You can find something in better shape for that price in the Seattle area and have it shipped to you cheaper than fixing all those issues. Here's a few listed on craigslist recently- http://seattle.craigslist.org/tac/car/298552084.html http://seattle.craigslist.org/see/car/300070299.html http://seattle.craigslist.org/skc/car/300692902.html http://seattle.craigslist.org/tac/car/295435819.html http://seattle.craigslist.org/skc/car/301804624.html Try using Crazedlist.org to search multiple Craigslist sites.
#15 |
Look at the top of the side rails, looks real rusty there. I agree with bouncy!
#16 |
SKINNY TIRES RULE!
Remember, Blazers have a "season" and it is quickly approaching. You will see more and more for sale in the coming months. Of course, the price tends to go up with the demand.
#17 |
The LuvShack Garage
Unless you just gotta have it, I'd pass, JMHO
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#18 |
SKINNY TIRES RULE!
Hey, I got an idea. Buy GQ from LUV! Just, umm, slightly more than that Jimmy you're looking at, but well worth the price.
#19 |
The LuvShack Garage
#20 |
![]() Join Date: May 2006
ROTFLMAO, you guys kill me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-28-2007 at 05:52 PM. |
#21 | |
Big Block
#22 |
Okay everybody - I have officially passed on the Jimmy and the search continues - I guess I will have to start my searches out West...(or hope somebody in the MidWest got one out there and transported it back here).
Thanks for the assistance on this one - I don't want to get burned and spend more time/energy (and more importantly $) working and fixing things than enjoying it. Last edited by lks dcvn; 03-28-2007 at 11:33 PM. |
#23 |
SKINNY TIRES RULE!
This one looks like a good buy. http://seattle.craigslist.org/tac/car/303303562.html
The guy just dropped the price which tells me he wants/needs to sell. You could probably have it shipped for $800 and still be into it for less than the other truck you were considering with all the repairs it needed.
#24 |
I saw that - I am still heading to Columbus tomorrow (but not checking out a Jimmy) - visiting the GFs relatives.
I saw the price drop - I have been watching Craig's List like a hawk for the past couple of days... I have emailed about 10 people back about their ads - some were sold, some haven't responded yet, and the rest sent pix of a rust bucket that was about the same as the Jimmy I was looking at. I will contact this seller over the weekend and see what can be worked out - I will likely find that it has been sold (but that just means that the one meant for me has yet to find it's way to me) - little silver lining mindset there. Thanks again everybody for your help on this - I really appreciate it. I have always wanted a 1st Gen - but just haven't been able to find one that I could 'pull the trigger on' yet. I am sure the day will come (likely the end of the season when somebody is trying to get rid of it before having to store it for another year...) when it will happen. Have a great weekend everybody! Tom Toledo, Ohio |
#25 | |
Oh..never mind....
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
