47-54 bed pics please
Im building my own bed that will allow me to raise up my rear fenders so I can lay my running boards on the ground with my 20's. Im Looking for any and all pictures yall may have of your bed, friends bed, or just a bed you've seen. Please keep the pics limited to 47-54, thanks.
![]() Join Date: Mar 2007
Re: 47-54 bed pics please
Hey long time no talk. Marc here from Michigan.
Are you sure that you need to raise the fenders? On mine, I raised the floor about 2" to clear the frame. I think that as long as I trim the inner fender braces I should be OK. My truck is about 1 5/8 in the back from laying out. I would need to change my notch and move my disc brake calipers in order to layout. I am not sure if I want to go through that for 1 5/8. I will post some pics of my bed tomorrow for you. My bed looks stock other then the inner fenders that I added in order to run a 10" wide rim. |
yea the tires bottom out in the fenders when the running boards are about 1.5 inches from the ground
since I went though hell getting the frame to lay running board on 20's, I will raise the bed with my fenders so that I can extend the bottom of the fenders to meet back with my running boards. I will extend the bottom of the bedsides and back piece as well so that everything looks "right" I've given this alot of thought, I just need pictures to finalize my idea. |
Here are some pics
![]() Notice the distance between the boards and the rear cross sill. This will give you an idea of how much the floor has been raised. ![]() ![]() ![]() I am curious what size tires do you plan on using? |
255/35/20
27" inches tall |
I hope this helps:
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
Where did you get the tubs for the bed? Are they from a stepside bed or for a different application?
#8 | |
They are 2 3/4 inch wide, They are expensive but they are very nice qualtity. |
I started on my bedfloor...
You have made a lot of progress in a short time. It looks good.
How is your brothers truck coming along? Keep up the good work |
its not...he's away at college so it just sits. that and every time he does work on it redoing something making it a little more wild...
