03-28-2007, 01:36 PM | #1 |
72 10 Drop Spindle Question
Does anyone know if Belltech #3120 (71-72 c10)Drop Spindles are made for 1.25" or 1" rotors? Also, has anyone tried using the Belltech #3100 (73-87 C10) drop spindles on a 72 setup? What all needs to change to make it work?
Thanks, |
03-28-2007, 01:47 PM | #2 |
Re: 72 10 Drop Spindle Question
I think the belltech 3120 is for 1" rotor. I would call them to make sure though. The 3100 would work for you and they are for 1.25 rotor. You would have to change your upper and lower balljoints to 73-87. The 3100 is $259.00 on summit. The cheaper way to go is get the DJM DS2045H-3 which are also for 1.25 rotors. They are $229.00 on summit. Little bit of savings... I ordered mine yesterday.
03-28-2007, 02:47 PM | #3 |
Thanks for the input...DJM DS2045H-3 it is!!!!
03-29-2007, 11:20 PM | #4 |
ok so if i have a 72 c10 with 1 in rotors and buy spindles that are 73 i have to change upper and lower balljoints what about the rotors and calibers do them need to be changed or can i get 73 spindles that are 1 in
03-30-2007, 01:58 PM | #5 |
73-87 spindles come in light duty (1inch) and heavy duty (1.25 inch). You can find both for sale, you just gotta know which one you're buying.
03-30-2007, 03:25 PM | #6 |
alright thank you
