Old 03-28-2007, 03:00 PM   #1
twitchyfinger
twitchyfinger's Avatar
Question Replacement Gas Tank from LMC question
I just ordered a replacement gas tank Kit from LMC (part# 32-5926). In the newest catalog there is a note for Blazer application that states: Fuel neck modification required on 1969-72 Blazers involving the transfer of the original fuel neck extension to the replacement tank. I was hoping someone might know what that actual modification is. I tried calling LMC and they replied with: "other people have asked the same question but they have no info on the modification". Any help would be greatly appreciated.
ΜΩΛΩΝ ΛΑΒE!
1971 K5 Blazer, 350 crate motor, 6" super lift, 35" Wild Country mud's on 16x10's
2000 Dodge Ram 1500 Quadcab 4x4
twitchyfinger is offline   Reply With Quote
Old 03-28-2007, 03:39 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Replacement Gas Tank from LMC question
The repop tank is a happy medium between the Sub and Blazer tanks. The repop's neck isn't as long nor is it in the correct clock position. Take your old tank and the new one to radiator shop and they'll do the swap for $20-50.
70rs/ss is offline   Reply With Quote
Old 03-30-2007, 12:06 PM   #3
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
I got the same tank I just used a longer hose with a spring rapped in the inside of the rubber so it wouldn't collapse its a Marine hose worked fine. Its a little tight getting it in but it worked
Angelse68cal is offline   Reply With Quote
Old 03-30-2007, 01:11 PM   #4
GMCPaul
The blazer tank has a curve in the filler neck and is longer than the shorter straight neck on the replacement tank, most generally use the longer reinforced hose method others swap necks.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 03-30-2007, 03:33 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Was price the reason you didn't get it from a Board Vendor? Just curious?
*Most of the board vendors here cut us deals and have better service
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-30-2007, 04:06 PM   #6
twitchyfinger
LMC was the only place I knew of that had a gas tank avaliable. I even tried an internet search which didn't turn up much.
I appreciate everyone's help and does not sound like too big a deal. The thing that gets me torqued is that I ordered from an earlier (not their latest) LMC catalog and in the catalog that I have and thus the reason for ordering it says " direct OE replacement tank". Had I know before hand it needed to me modified I might have looked harder for a tank somewhere else. Price was not the factor I was looking for something that would be a direct replacemant without much modification.
BTW: I will think twice and look for other places before ordering from them again.
ΜΩΛΩΝ ΛΑΒE!
Old 03-30-2007, 04:34 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No biggie, I just know that the vendor here I use usually kills their prices,
but the real reason that I use him is his service and knowledge support
List of Vendors can be found HERE (Just scroll down to the RED names)
Old 03-30-2007, 08:18 PM   #8
herb101
Used Register
herb101's Avatar
This might help...
http://67-72chevytrucks.com/vboard/s...d.php?t=212828
not from LMC, but similar experience I wrote up.
Herb
herb101 is offline   Reply With Quote
Old 03-30-2007, 08:38 PM   #9
71jimmy
71jimmy's Avatar
The board vendors are great but LMC has a great catalog. I found that everyone sells the same tanks, with the short filler neck. Doesn't matter where you buy from they either have to be modified or the reinforced hose needs to be used.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 03-30-2007, 08:43 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I agree 100%, the LMC catalog is top notch for Pic reference, and that is
one item that it doesn't really matter where it comes from because I bet
they're all from the same factory I hate their service, or lack there of
Old 03-30-2007, 09:17 PM   #11
twitchyfinger
I agree with you 100% on that!
It's kind of hard to find out what the other vendors here actually have for sale and is the plus side to the catalog. The customer service attitude when calling LMC was the "don't ask me I just work here!"
I have a big wish list for things I would like for by Blazer, I am going to have to do some homework and see what the other vendors have.
So possibly a marine store for the reinforced filler hose?
ΜΩΛΩΝ ΛΑΒE!
Old 04-01-2007, 07:10 AM   #12
Green Monster
Green Monster's Avatar
Just curios... the tank on my Blazer was replaced with a plastic tank by the previous owner. I'm under the impression plastic tanks were not original, right? Are replacement tanks available in metal and plastic? Or was this tank used from another application? The filler neck hose that the PO used is kinked and needs to be shortened to remove the kink, I think. I suppose filler necks are a bit of an issue and are not just a direct replacement on Blazers and Jimmys.
Green Monster is offline   Reply With Quote
Old 04-01-2007, 07:56 AM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
You can get the replacement tank in Metal or Plastic, both are correct for
the application, both will need to have modified hoses, spring inside types
are better since they do not kink, OEM ones on all Blazers were Metal.
Old 04-01-2007, 10:42 AM   #14
Green Monster
Spring inside? Is there a metal spring inside that may be prone to rust, or is it molded into the rubber hose itself? Where do I get one?
