Old 03-28-2007, 03:46 PM   #1
xtreme80
Wishin' I had more money!
xtreme80's Avatar
3.73 w/ posi or my ignition
On one hand, I've got a bad ignition miss. The truck will sputter and idle rough because of it.
On the other hand, I can get my hands on a complete 3.73 rear end with posi, for about the same price as the ignition system.
Can't do both right now.
What would you do?
xtreme80 is offline   Reply With Quote
Old 03-28-2007, 03:55 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: 3.73 w/ posi or my ignition
So what would you be replacing on the ignition system that would cost as much as a posi rear end
No brainer the posi!!!
Malo83 is offline   Reply With Quote
Old 03-28-2007, 03:59 PM   #3
ureckme
ureckmefixit2@cox.net
Well if it don't run you can't drive it over to my house to tell you whats really wrong with it. lol If you can get the miss fixed on the cheep than get the rear end too. I just got my rear end 12 bolt 3.73 w/posi off creigslist for $150. Got it from a guy in Chandler. It has new Richmond gears and new posi and i'm putting it in this weekend.
Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 03-28-2007, 04:25 PM   #4
82c10
needin' money
for less than $60 you can have a new HEI >It was stolen about 5-6 years ago (before Ryan owned it) so the insurance company paid for it. It was recovered w/ no damage but it has a rebuilt title now.
get some store brand wires from autozone, or other chain parts store-less than $20
and sparkplugs can be had from wal-mart for around $13
60+20+13= $93, fix it first, you can get performance parts later
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 03-28-2007, 05:10 PM   #5
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
posi, ignition can be fixed anytime how offen do you get a 12 bolt rear for near to nothin
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-28-2007, 05:46 PM   #6
82c10
needin' money
ok, we'll i can probably get at least 2-3 of them for less then $100 each, i can go get another posi 8.8 disc brake rear with 3.55's for less then $100, and when they roll some more in i can get another 3.73 rearend for less then $100, and yes i am sure i can find these, you just have to look, to me $100 is alot, coming from what i have done i will fix what i have before i buy a performance part for it
Old 03-28-2007, 05:47 PM   #7
82c10
needin' money
and according to his sig he already has a 3.73 rearend with posi
Old 03-28-2007, 06:02 PM   #8
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
If I sent you 100+ shipping would you hook me up with one??
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 03-28-2007, 06:08 PM   #9
82c10
needin' money
if i had the time to go pull one, and ship it, i would, but i don't have time with school and work these days, maybe in a couple months
Old 03-28-2007, 06:19 PM   #10
Rc 415
Rc 415's Avatar
mabye i could compensate you for the labor
Old 03-28-2007, 06:59 PM   #11
Pyrotechnic
Pyrotechnic's Avatar
Are you sure you dont just need a cap/rotor/coil/wires/plugs ? If the HEI is really old the mechanical advance mechanism will be very sloppy and will cause the motor to run less than great sometimes during part throttle and acceleration as the advance will be coming in and out constantly. You can probably find a used in good shape for not too much.
I had one that had a really sloppy and worn out advance mechanism, but even then the truck still pretty decently with a good cap, rotor, coil, wires, and plugs. Sometimes you would stomp down on it and acceleration would be mediocre and other times it would bark the tires like crazy when it hit 2nd gear. That was rare though and the truck ran great for the most part.
Unless the mechanism is seriously damaged, like the weights stuck completely in any given position, it sounds like it might just need a tune up.
Pyrotechnic is offline   Reply With Quote
Old 03-28-2007, 10:58 PM   #12
jermasaurus
jermasaurus's Avatar
umm... thats a no brainer. Fix the ignition!!! You must get the truck running correctly before buying things that are not necessary.
What is wrong with the ignition? Your "bad miss" can be anything from a plug/wire to a flattened cam lobe.
Besides, leaving the truck running poorly can only amount to worse problems. These problems can be more serious on emisions vehicles- like damage to catalytic converters.
Either way, I would worry about getting the truck running properly first
Good luck
-Jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 03-28-2007, 11:07 PM   #13
boatpuller
boatpuller's Avatar
i'm gonna have to agree with jermasaurus.man you gotta be able to get from point a to point b,if it isn't a daily driver then it might be different.get that bugger running right then worry about the hind end.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-28-2007, 11:10 PM   #14
xtreme80
xtreme80's Avatar
The truck has an ignition miss. It's not bad, but it bothers me. It's a very slight miss and only does it about every 10 seconds when idling. It's never come close to dying or anything.
It's not a worn cam lobe. The engine is a GM crate with about 1000 miles on it.
I guess I posted this wrong. It's not like it's about to break, it's just a little shutter in the ignition when sitting at a stop light. Nothing major.
Someone pointed out my sig saying I already had the 3.73. Well, I put that up there the day I was supposed to go get the rear end. That fell through, but I can get it for sure tomorrow.
And yes, the new rear end is a rebuilt one with 0 miles and posi for about 100 bucks.
Old 03-29-2007, 02:47 AM   #15
ureckme
sounds like a lean miss or the carb has a drip that makes it do that
74 Chevy Short Bed
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
Old 03-29-2007, 04:08 AM   #16
Pyrotechnic
Thats a great price for that, as long as the rebuilt was done right. A new posi unit alone costs more than that to begin with.
Old 03-29-2007, 10:16 PM   #17
slugish
Slugish
Is your distributer or msd box grounded to the engine block. Very important . found out the hard way
slugish is offline   Reply With Quote
Old 03-29-2007, 10:51 PM   #18
jermasaurus
Hope I didn't come off sounding rude. It sounded like a typical situation I see at work here and there. But you say it only misses once every 10 sec or so? Did you use new plugs/wires/cap/rotor when you dropped that morot in?
Old 03-29-2007, 11:13 PM   #19
xtreme80
xtreme80's Avatar
Ok guys, I went ahead and did the ignition. I got a new cap, rotor, and HEI coil.
I hooked it up to the multi and it showed teh coil as being bad. Also, the old cap and rotor were cheap autozone parts, so I went with some good stuff from work.
With all 3 items, I payed about 40 bucks. Gotta love shop discounts.
But all this fixed the problem. Turns out I had another problem that was slowly developing that was also directly related to this. At high RPM the engine was hesitating BAD. It felt as if it was starved for fuel, or as if I was letting off the gas for a minute, then back on. It was getting worse and worse, and these new parts fixed that as well.
I guess the rear end will have to wait. There's no sense in having it if the ignition is fubar'd
