Old 03-28-2007, 06:19 PM   #1
SkylineNXS
SkylineNXS's Avatar
Oil
Kind of a stupid question, but what oil do u 350 guys put in ur motors? I dont have a manual to tell me / do u guys use the high performance or high milage? Thanks.....
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 03-28-2007, 06:39 PM   #2
SkylineNXS
SkylineNXS's Avatar
Re: Oil
anybody.....??
Old 03-28-2007, 06:58 PM   #3
68 P.O.S.
Re: Oil
I'm using Royal Purple 20/50.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-28-2007, 07:11 PM   #4
cdowns
cdowns's Avatar
Re: Oil
for new engines and freash rebuilds i break in with 10-40quaker state then change to mobil one synthetic// old engines i stick with quaker state 10-40 regular oil because going synthetic after an engine has a couple of hundred thousand miles leads to leaks
Old 03-28-2007, 07:13 PM   #5
chevyboy55
chevyboy55's Avatar
Re: Oil
Valvoline 10-40
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 03-28-2007, 07:21 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Oil
with the lack of zink in all the gassoline oils, I say stick to diesel oils. I run rotella 15/40 in mine.
Old 03-28-2007, 09:49 PM   #7
connman
Re: Oil
What does zinc have to do with lubricating an engine? First time I've heard of that.
connman is offline   Reply With Quote
Old 03-28-2007, 09:56 PM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Oil
flat tapped cammed engines need the zinc
and im running havoline 20/50 right now but gona change to something else cause of the zinc
does the kendal oil have good zinc content???
or am i better off with rotella
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-28-2007, 10:42 PM   #9
6872xtc
6872xtc's Avatar
Re: Oil
according to 'Chevy High Performance' magazine, only diesel oils and racing oils have the ZDDP, or zinc phosphate additive at a level to sustain a flat tappet cam nowadays. Royal Purple tells me that they do and always will. My 454 just received a complete rebuild due to the cam, the oil, and my own bad luck. 25000 miles and cam knocked chunks off the lifters, they got up into the cylinders, so it's now .020 over and roller cammed. Supposedly you can use GM cam and lifter prelube at every oil change with any oil if ZDDP content of your oil is low. Royal Purple told me that if my engine would of had their oil in it, they would have covered cost of oil related failure. I don't know how true that is, but seems interesting.
6872xtc is offline   Reply With Quote
Old 03-28-2007, 10:44 PM   #10
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Oil
IMO no question is stupid only some answers are stupid and from what I can see none of the ones you got here were that. I agree with them all. Thiszinc content thing is one we all need to keep an eye on IMO. The are alot of good advice floating around here on the subject just do a seach and you will find some GR8 links on the subject.
As for my answer to the question I run Mobil 1 full syn. in all newwer vehicals. H-D in the bike. RED LINE in any thing of perfomance nature. my .02 RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-28-2007, 11:43 PM   #11
GREASEMONKEY72
Re: Oil
so valvoline racing oil has the zinc we need?
and all royal purple oil has it to?
and does the kendal oil have the zinc we need?
-steven
Alte Seele S.S.
Old 03-29-2007, 12:05 AM   #12
snj8198
snj8198's Avatar
Re: Oil
Im going to Royal Purple after I fix the mess Valvoline left me with another wiped flat tappet and lobe in my MkIV block.
snj8198 is offline   Reply With Quote
Old 03-29-2007, 12:33 AM   #13
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Oil
Rotella 15-30 w/ K&N filter...new engine.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 03-29-2007, 02:18 AM   #14
sjarrett71
sjarrett71's Avatar
Re: Oil
I've alwys used Valvoline in everything I have ever owned and never had a problem. Of course, I don't keep things too long either.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-29-2007, 02:55 AM   #15
chevguy7
chevguy7's Avatar
Re: Oil
10-40 in mine. valvoline, halvoline, or quaker
chevguy7 is offline   Reply With Quote
Old 03-29-2007, 09:07 AM   #16
manimal
manimal's Avatar
Re: Oil
I have also read that the DIESEL OILs will also be reformulated to remove the ZDDP. Thanks to the EPA. So if you're running dino oils then get the GM cam break in lube everytime you change your oil.
-Lance
manimal is offline   Reply With Quote
Old 03-29-2007, 12:00 PM   #17
timcos
Chief Honcho In Charge
timcos's Avatar
Re: Oil
I put 5w40 in mine. Change it every 90 days or 3000 miles...whichever comes forst.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 03-29-2007, 12:02 PM   #18
timcos
timcos's Avatar
Re: Oil
Hey....how does one know if they have a flat tappet engine. I have a stock 350...remanned by Jasper. I guess I could ask them.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 03-29-2007, 12:45 PM   #19
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Oil
Amsoil 5W-30 synthetic in my 02 GMC and the wifes 02 Monte Carlo SS, Amsoil Synthetic Premium 10W-40 in my 68 and 70 Chevys (both are new motors, < 2000 miles each), and Amsoil Interceptor 2-Cycle oil and chaincase oil in the snowmobiles.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
