Old 03-28-2007, 11:18 PM   #1
SSC's76
No No
SSC's76's Avatar
Got some pics but it still isnt done:(
Ok so the engine is all good but the transmission isnt looking so good. I got the 97-00 clutch today. The pressure plate is maybe an 1/8 of an inch shorter then the older setup. Figured I should be able to make the difference up in the clutch rod adjustment. Dosent seem to be working too well. I did take it out for a short trip around the block and lets just say it runs real well. Ok well enough to break the tires loose in 2nd at 30 mph. Hmh I guess only 1 pic is small enough to upload right now.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 03-29-2007, 08:08 AM   #2
Zilverado
Zilverado's Avatar
Re: Got some pics but it still isnt done:(
Sounds like you're having fun with it...
As for the pictures, the maximum file size allowed by the forum is 100 kilobytes. Check if your using .jpg format pictures - - they have small digital file size. Also, try taking the photos with lower resolution on the camera.
Keep 'em coming.
Zilverado is offline   Reply With Quote
