Which year s10 weatherstripping?
What year s10 weatherstripping do we need for our doors? Can we get it at the junkyard (will it be long enough) or do we have to order new and cut to fit? Thanks for the help all! My truck currently has none and it is super loud!!!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#2 | |
Re: Which year s10 weatherstripping?
LMC Truck
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
Thanks for the links fleet72, but I'm trying to avoid using stock weatherstripping that has to be glued in. A long time ago (years) someone discovered that door weatherstripping from an S10 would fit our doors. It has metal in it so that it clips to the lip around the door frame. I remember the orner mitre isn't perfect, but other than that it works well! THanks for the links though!
SHawn
Never mind!! I finally was able to find the links using search. I guess we are using 78-93 dodge parts now. The s10 has gone by the wayside! Thanks anyways guys!!
SHawn
chevy truck fan
fyi... i pulled a set from a late model (mid'90) truck. i pulled off jy truck, cleaned, armoralled, & pushed back onto my '72 & then cut about a foot from it. it works great! no mess no fuss.
just a thought... rodstored-72 |
#6 | ||
I'd like to know which press on weather stripping works as well... what model/years of trucks that work.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
gmcpauls.com has some for sale.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
Okay... Here is what I did:
I went to the jyard , but couldn't find any off a dodge that were in decent shape. So I looked at a after 2000 chevy. It is the extended cab with 4 doors that open, not three. I pulled those, then compared them to the the dodge they had, they are nearly identical! The width, etc. I really want to say identical, but I'm sure there is some minute difference. I got them both for 20.00. They installed pretty easy, but I had to remove a piece of foam that is inside the middle (where the extended doors are). I merely cut a small slit on the inside lip and pulled it out. easy. Cut to fit and install. The passenger door is nice and firm with a close. The driverside door is a little harder, but I'm sure that will change over time. Best of all I had about 5 foot left over on each peice, so I know they are plenty long. Hope this helps some! SHawn
#10 | |
Yeah, I read your reply this morning at work but couldn't reply. I found the other thread regarding the use of s-10 weatherstripping. I have an 89 sitting in the driveway so maybe I give it a go! Thanks for bringing this to my attention.
