Old 03-29-2007, 01:50 AM   #1
sbc406c10
posi code
does anyone know the code for a factory posi in the 73-87's? i'm headed out to the junkyard this weekend to find a posi rear end, hopefully i will get a chance to look through all of the trucks, but what are some ways to tell if its an posi without taking the cover off the rear end?
sbc406c10 is offline   Reply With Quote
Old 03-29-2007, 11:11 AM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: posi code
With the trucks as old as they are there is no way to tell if it is a LSD without removing the cover.
G80 is the option code for them though. In general, the 12bolts have the Eaton clutch style unit, and the 10bolts have the Eaton Gov-Loc.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-29-2007, 11:16 AM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: posi code
I was told to jack it up and turn the wheel and if the other wheel turn, In th same direction its a posi. BUt i could be wrong been so long sents iv been told that.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-29-2007, 11:25 AM   #4
Captkaos
Captkaos's Avatar
Re: posi code
If the unit is tight and it is a clutch setup that "could" be fairly accurate, but it the clutches are worn, it will act like an open diff.
The test won't work on a gov-loc though, it uses flyweights to engage, so it will always act like an open until it senses slip.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-29-2007, 12:23 PM   #5
sbc406c10
Re: posi code
ok, thanks a lot guys for the info
